Apache2.4-PHP_8.0-8.1, PHP_8.1, MySQL-8.0-Win10
Это пишет при авторизации в phpMyAdmin
Основной лог:mysqli::real_connect(): (HY000/2002): Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение
Лог Apache:2023-09-14 11:21:34 Запуск MySQL-8.0-Win10
2023-09-14 11:21:34 Запуск Apache_2.4-PHP_8.0-8.1+Nginx_1.23
2023-09-14 11:21:34 Проверка состояния сервера
2023-09-14 11:21:51 Не удалось запустить MySQL-8.0-Win10
2023-09-14 11:21:51 Сбой запуска!
Логи MySql:[Thu Sep 14 11:21:34.734400 2023] [ssl:warn] [pid 6372:tid 120] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Thu Sep 14 11:21:34.783400 2023] [mpm_winnt:notice] [pid 6372:tid 120] AH00455: Apache/2.4.54 (Win64) OpenSSL/3.0.5 configured -- resuming normal operations
[Thu Sep 14 11:21:34.783400 2023] [mpm_winnt:notice] [pid 6372:tid 120] AH00456: Server built: Jul 26 2022 23:58:26
[Thu Sep 14 11:21:34.783400 2023] [core:notice] [pid 6372:tid 120] AH00094: Command line: 'G:\\ospanel\\modules\\http\\Apache_2.4-PHP_8.0-8.1+Nginx_1.23\\bin\\httpd.exe -d G:/OSPanel/modules/http/Apache_2.4-PHP_8.0-8.1+Nginx_1.23 -f g:\\ospanel\\modules\\http\\Apache_2.4-PHP_8.0-8.1+Nginx_1.23\\conf\\httpd.conf'
[Thu Sep 14 11:21:34.793400 2023] [mpm_winnt:notice] [pid 6372:tid 120] AH00418: Parent: Created child process 6664
[Thu Sep 14 11:21:35.355400 2023] [ssl:warn] [pid 6664:tid 128] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Thu Sep 14 11:21:35.393400 2023] [mpm_winnt:notice] [pid 6664:tid 128] AH00354: Child: Starting 128 worker threads.
2023-09-14T08:21:34.309401Z 0 [System] [MY-010116] [Server] g:\ospanel\modules\database\MySQL-8.0-Win10\bin\mysqld.exe (mysqld 8.0.30) starting as process 6880
2023-09-14T08:21:34.330400Z 0 [Warning] [MY-013907] [InnoDB] Deprecated configuration parameters innodb_log_file_size and/or innodb_log_files_in_group have been used to compute innodb_redo_log_capacity=67108864. Please use innodb_redo_log_capacity instead.
2023-09-14T08:21:34.333400Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2023-09-14T08:21:34.374401Z 1 [ERROR] [MY-012209] [InnoDB] Multiple files found for the same tablespace ID:
2023-09-14T08:21:34.375400Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 39 = ['venam0\migrations.ibd', 'venam_test\alerts.ibd']
2023-09-14T08:21:34.375401Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 40 = ['venam0\users.ibd', 'venam_test\categories.ibd']
2023-09-14T08:21:34.375402Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 41 = ['venam0\password_resets.ibd', 'venam_test\cities.ibd']
2023-09-14T08:21:34.375403Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 43 = ['venam0\oauth_auth_codes.ibd', 'venam_test\failed_jobs.ibd']
2023-09-14T08:21:34.375404Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 45 = ['venam0\oauth_access_tokens.ibd', 'venam_test\kaspi_products.ibd']
2023-09-14T08:21:34.375405Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 47 = ['venam0\oauth_refresh_tokens.ibd', 'venam_test\migrations.ibd']
2023-09-14T08:21:34.375406Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 48 = ['venam0\oauth_clients.ibd', 'venam_test\moonshine_change_logs.ibd']
2023-09-14T08:21:34.375407Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 49 = ['venam0\oauth_personal_access_clients.ibd', 'venam_test\moonshine_socialites.ibd']
2023-09-14T08:21:34.375408Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 50 = ['venam0\failed_jobs.ibd', 'venam_test\moonshine_user_permissions.ibd']
2023-09-14T08:21:34.375409Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 51 = ['venam0\personal_access_tokens.ibd', 'venam_test\moonshine_user_roles.ibd']
2023-09-14T08:21:34.375410Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 53 = ['venam0\cities.ibd', 'venam_test\notifications.ibd']
2023-09-14T08:21:34.375411Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 55 = ['venam0\kaspi_products.ibd', 'venam_test\oauth_auth_codes.ibd']
2023-09-14T08:21:34.375412Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 56 = ['venam0\jobs.ibd', 'venam_test\oauth_clients.ibd']
2023-09-14T08:21:34.375413Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 58 = ['venam0\translations.ibd', 'venam_test\oauth_refresh_tokens.ibd']
2023-09-14T08:21:34.375414Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 59 = ['venam0\orders.ibd', 'venam_test\order_lists.ibd']
2023-09-14T08:21:34.375415Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 60 = ['venam0\order_lists.ibd', 'venam_test\orders.ibd']
2023-09-14T08:21:34.375416Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 62 = ['venam0\categories.ibd', 'venam_test\personal_access_tokens.ibd']
2023-09-14T08:21:34.375417Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 63 = ['venam0\proxies.ibd', 'venam_test\product_potentials.ibd']
2023-09-14T08:21:34.375418Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 64 = ['venam0\transactions.ibd', 'venam_test\product_warehouse.ibd']
2023-09-14T08:21:34.375419Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 65 = ['venam0\kaspi_robot_log.ibd', 'venam_test\products.ibd']
2023-09-14T08:21:34.375420Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 66 = ['venam0\stores.ibd', 'venam_test\proxies.ibd']
2023-09-14T08:21:34.375421Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 67 = ['venam0\alerts.ibd', 'venam_test\recommendations.ibd']
2023-09-14T08:21:34.375422Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 69 = ['venam0\site_settings.ibd', 'venam_test\site_settings.ibd']
2023-09-14T08:21:34.375423Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 70 = ['venam0\recommendations.ibd', 'venam_test\stores.ibd']
2023-09-14T08:21:34.375424Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 72 = ['venam0\product_potentials.ibd', 'venam_test\tariffs.ibd']
2023-09-14T08:21:34.375425Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 73 = ['venam0\warehouses.ibd', 'venam_test\tariffs_stores.ibd']
2023-09-14T08:21:34.375426Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 76 = ['venam0\product_warehouse.ibd', 'venam_test\telescope_monitoring.ibd']
2023-09-14T08:21:34.375427Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 79 = ['venam0\customers.ibd', 'venam_test\users.ibd']
2023-09-14T08:21:34.375428Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 80 = ['venam0\products.ibd', 'venam_test\warehouses.ibd']
2023-09-14T08:21:34.375429Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Failed, retry may succeed.
2023-09-14T08:21:34.375430Z 1 [ERROR] [MY-010334] [Server] Failed to initialize DD Storage Engine
2023-09-14T08:21:34.376400Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
2023-09-14T08:21:34.376401Z 0 [ERROR] [MY-010119] [Server] Aborting
2023-09-14T08:21:34.376407Z 0 [System] [MY-010910] [Server] g:\ospanel\modules\database\MySQL-8.0-Win10\bin\mysqld.exe: Shutdown complete (mysqld 8.0.30) MySQL Community Server - GPL.
