не работает импорт БД WP из-за строк CONSTRAINT ...
одинаково не работает и в bigdump и в phpmyadmin OpenServer
bigdump https://www.ozerov.de/bigdump/ обычно работает, я заливал ним всегда большие БД так как он лучше (надёжнее) чем phpmyadmin.
пробую такой же SQL-ЗАПРОС В phpmyadminBigDump: Staggered MySQL Dump Importer v0.36b
Processing file: themes11_v101_22avg23.sql
Starting from line: 1
Error at the line 2679: ) ENGINE=InnoDB AUTO_INCREMENT=5 DEFAULT CHARSET=utf8;
Query: CREATE TABLE `f6q9u3pk7v_supsystic_ss_project_networks` (
`id` int(11) unsigned NOT NULL AUTO_INCREMENT,
`project_id` int(11) unsigned DEFAULT NULL,
`network_id` int(11) unsigned DEFAULT NULL,
`position` int(11) unsigned DEFAULT '0',
`title` varchar(255) DEFAULT NULL,
`text` varchar(255) DEFAULT NULL,
`tooltip` varchar(255) DEFAULT NULL,
`text_format` varchar(255) DEFAULT NULL,
`profile_name` varchar(255) DEFAULT NULL,
`icon_image` int(11) unsigned DEFAULT NULL,
`use_short_url` bit(1) DEFAULT NULL,
`mail_to_default` varchar(255) DEFAULT NULL,
PRIMARY KEY (`id`),
KEY `FK__f6q9u3pk7v_supsystic_ss_projects` (`project_id`),
KEY `FK__f6q9u3pk7v_supsystic_ss_networks` (`network_id`),
CONSTRAINT `FK__f6q9u3pk7v_supsystic_ss_networks` FOREIGN KEY (`network_id`) REFERENCES `f6q9u3pk7v_supsystic_ss_networks` (`id`),
CONSTRAINT `FK__f6q9u3pk7v_supsystic_ss_projects` FOREIGN KEY (`project_id`) REFERENCES `f6q9u3pk7v_supsystic_ss_projects` (`id`) ON DELETE CASCADE
MySQL: Can't create table `tw`.`f6q9u3pk7v_supsystic_ss_project_networks` (errno: 150 "Foreign key constraint is incorrectly formed")
Stopped on error
аналогично SQL-ЗАПРОС В phpmyadminОшибка
SQL запрос: Копировать
CREATE TABLE `f6q9u3pk7v_supsystic_ss_project_networks` ( `id` int(11) unsigned NOT NULL AUTO_INCREMENT, `project_id` int(11) unsigned DEFAULT NULL, `network_id` int(11) unsigned DEFAULT NULL, `position` int(11) unsigned DEFAULT '0', `title` varchar(255) DEFAULT NULL, `text` varchar(255) DEFAULT NULL, `tooltip` varchar(255) DEFAULT NULL, `text_format` varchar(255) DEFAULT NULL, `profile_name` varchar(255) DEFAULT NULL, `icon_image` int(11) unsigned DEFAULT NULL, `use_short_url` bit(1) DEFAULT NULL, `mail_to_default` varchar(255) DEFAULT NULL, PRIMARY KEY (`id`), KEY `FK__f6q9u3pk7v_supsystic_ss_projects` (`project_id`), KEY `FK__f6q9u3pk7v_supsystic_ss_networks` (`network_id`), CONSTRAINT `FK__f6q9u3pk7v_supsystic_ss_networks` FOREIGN KEY (`network_id`) REFERENCES `f6q9u3pk7v_supsystic_ss_networks` (`id`), CONSTRAINT `FK__f6q9u3pk7v_supsystic_ss_projects` FOREIGN KEY (`project_id`) REFERENCES `f6q9u3pk7v_supsystic_ss_projects` (`id`) O[...]
Ответ MySQL:
#1005 - Невозможно создать таблицу `tw`.`f6q9u3pk7v_supsystic_ss_project_networks` (ошибка: 150 "Foreign key constraint is incorrectly formed") (Детали…)
плагин WP "Social Share Buttons by Supsystic"DROP TABLE IF EXISTS `f6q9u3pk7v_supsystic_ss_shares`;
/*!40101 SET @saved_cs_client = @@character_set_client */;
/*!40101 SET character_set_client = utf8 */;
CREATE TABLE `f6q9u3pk7v_supsystic_ss_shares` (
`post_id` int(11) unsigned DEFAULT NULL,
`timestamp` timestamp NULL DEFAULT CURRENT_TIMESTAMP,
PRIMARY KEY (`id`),
KEY `FK_f6q9u3pk7v_supsystic_ss_shares_networks` (`network_id`),
KEY `FK_f6q9u3pk7v_supsystic_ss_shares_projects` (`project_id`),
CONSTRAINT `FK_f6q9u3pk7v_supsystic_ss_shares_networks` FOREIGN KEY (`network_id`) REFERENCES `f6q9u3pk7v_supsystic_ss_networks` (`id`) ON DELETE CASCADE,
CONSTRAINT `FK_f6q9u3pk7v_supsystic_ss_shares_projects` FOREIGN KEY (`project_id`) REFERENCES `f6q9u3pk7v_supsystic_ss_projects` (`id`) ON DELETE CASCADE
) ENGINE=InnoDB AUTO_INCREMENT=4 DEFAULT CHARSET=utf8;
/*!40101 SET character_set_client = @saved_cs_client */;
https://wordpress.org/plugins/social-sh ... supsystic/
https://supsystic.com/plugins/social-share-plugin/
phpmyadmin нормально понимает это (в предыдущих таблицах импортировалось):Version: 2.2.9
Last updated: 1 year ago
Active installations: 6,000+
Tested up to: 6.0.5
я не пользуюсь в данный момент плагином WP "Social Share Buttons by Supsystic", поэтому могу просто удалить строки в файле SQL.ENGINE=InnoDB
AUTO_INCREMENT=5
однако слегка напрягает тот факт что запрос CONSTRAINT как-то работал при импорте и экспорте БД в ISP-manager но не работает phpmyadmin OpenServer.
