mysqli::real_connect(): (HY000/2002): Подключение не установлено, т.к. конечный компьютер отверг запрос на подключениеДанные для авторизации стояли обычные - логин: root, пароль - пусто.
Логи отладки Mysql:
2023-05-27T03:54:48.518714Z 0 [System] [MY-010116] [Server] c:\ospanel\modules\database\MySQL-8.0-Win10\bin\mysqld.exe (mysqld 8.0.30) starting as process 11784 2023-05-27T03:54:48.522665Z 0 [Warning] [MY-013907] [InnoDB] Deprecated configuration parameters innodb_log_file_size and/or innodb_log_files_in_group have been used to compute innodb_redo_log_capacity=67108864. Please use innodb_redo_log_capacity instead. 2023-05-27T03:54:48.524428Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started. 2023-05-27T03:54:49.487214Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended. 2023-05-27T03:54:49.717329Z 0 [Warning] [MY-010068] [Server] CA certificate c:/ospanel/userdata/MySQL-8.0-Win10/ca.pem is self signed. 2023-05-27T03:54:49.717526Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel. 2023-05-27T03:54:49.748509Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: '127.0.0.1' port: 33060 2023-05-27T03:54:49.748574Z 0 [System] [MY-010931] [Server] c:\ospanel\modules\database\MySQL-8.0-Win10\bin\mysqld.exe: ready for connections. Version: '8.0.30' socket: '' port: 3306 MySQL Community Server - GPL. 2023-05-27T03:54:50.668893Z 0 [ERROR] [MY-011853] [InnoDB] Corruption of an index tree: table `wordpress`.`sopedon_postmeta` index `PRIMARY`, father ptr page no 98, child page no 248 PHYSICAL RECORD: n_fields 6; compact format; info bits 0 0: len 8; hex 000000000000d471; asc q;; 1: len 6; hex 000000165c20; asc \ ;; 2: len 7; hex 82000000910110; asc ;; 3: len 8; hex 00000000000041dd; asc A ;; 4: len 17; hex 5f77705f61747461636865645f66696c65; asc _wp_attached_file;; 5: len 8; hex 343138372e6a7067; asc 4187.jpg;; PHYSICAL RECORD: n_fields 2; compact format; info bits 16 0: len 8; hex 0000000000000001; asc ;; 1: len 4; hex 00000062; asc b;; 2023-05-27T03:54:50.669272Z 0 [ERROR] [MY-011854] [InnoDB] [FATAL] You should dump + drop + reimport the table to fix the corruption. If the crash happens at database startup. Please refer to http://dev.mysql.com/doc/refman/8.0/en/ ... overy.html for information about forcing recovery. Then dump + drop + reimport. 2023-05-27T03:54:50.669288Z 0 [ERROR] [MY-013183] [InnoDB] Assertion failure: btr0btr.cc:700:ib::fatal triggered thread 4520 InnoDB: We intentionally generate a memory trap. InnoDB: Submit a detailed bug report to http://bugs.mysql.com. InnoDB: If you get repeated assertion failures or crashes, even InnoDB: immediately after the mysqld startup, there may be InnoDB: corruption in the InnoDB tablespace. Please refer to InnoDB: http://dev.mysql.com/doc/refman/8.0/en/ ... overy.html InnoDB: about forcing recovery. 03:54:50 UTC - mysqld got exception 0x16 ; Most likely, you have hit a bug, but this error can also be caused by malfunctioning hardware. Thread pointer: 0x2399eaa4ea0 Attempting backtrace. You can use the following information to find out where mysqld died. If you see no messages after this, something went terribly wrong... 7ff673ef0858 mysqld.exe!?my_print_stacktrace@@YAXPEBEK@Z() 7ff67308e92b mysqld.exe!?print_fatal_signal@@YAXH@Z() 7ff67308e6f3 mysqld.exe!?my_server_abort@@YAXXZ() 7ff673ed47fa mysqld.exe!?my_abort@@YAXXZ() 7ff67411ca99 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff673ff9643 mysqld.exe!??$endl@DU?$char_traits@D@std@@@std@@YAAEAV?$basic_ostream@DU?$char_traits@D@std@@@0@AEAV10@@Z() 7ff674182cc3 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff6741827c9 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff67417f0f9 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff67418932f mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff67418df82 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff67423761f mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff6742373cd mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff674237349 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff6742367f4 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff6742385b7 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff674235700 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff674235024 mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff674234e1c mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ff673ff8bb7 mysqld.exe!??$endl@DU?$char_traits@D@std@@@std@@YAAEAV?$basic_ostream@DU?$char_traits@D@std@@@0@AEAV10@@Z() 7ff673ff932b mysqld.exe!??$endl@DU?$char_traits@D@std@@@std@@YAAEAV?$basic_ostream@DU?$char_traits@D@std@@@0@AEAV10@@Z() 7ff6740b033d mysqld.exe!?deallocate@?$allocator@V?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@std@@@std@@QEAAXQEAV?$sub_match@V?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@@2@_K@Z() 7ffa757e1bb2 ucrtbase.dll!_configthreadlocale() 7ffa77387034 KERNEL32.DLL!BaseThreadInitThunk() 7ffa778a2651 ntdll.dll!RtlUserThreadStart() Trying to get some variables. Some pointers may be invalid and cause the dump to abort. Query (0): Connection ID (thread ID): 0 Status: NOT_KILLED The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains information that should help you find out what is causing the crash.
Перезагрузка сервера/ос не помогает. Подскажите, что можно сделать, чтобы починить это?
