Всем привет!
После очередного синего экрана OpenServer 5.4.2 перестал запускаться, пишет:
2022-12-17 21:05:18 --------------------------------------------
2022-12-17 21:05:18 Start server start-up procedure
2022-12-17 21:05:18 Updating Hosts file
2022-12-17 21:05:18 Updating configuration MariaDB-10.6-Win10
2022-12-17 21:05:18 Updating configuration of Sendmail
2022-12-17 21:05:18 Updating configuration PHP_8.1
2022-12-17 21:05:18 Updating configuration Redis-5.0
2022-12-17 21:05:18 Updating configuration PHPRedisAdmin
2022-12-17 21:05:18 Updating configuration PHPMyAdmin
2022-12-17 21:05:18 Updating configuration Apache_2.4-PHP_8.0-8.1
2022-12-17 21:05:18 Launch MariaDB-10.6-Win10
2022-12-17 21:05:18 Launch Redis-5.0
2022-12-17 21:05:18 Launch Apache_2.4-PHP_8.0-8.1
2022-12-17 21:05:18 Checking server status
2022-12-17 21:05:36 Failed to start MariaDB-10.6-Win10
2022-12-17 21:05:36 Failed to start!
2022-12-17 21:05:36 --------------------------------------------
2022-12-17 21:05:36 Beginning of procedure to stop server
2022-12-17 21:05:36 Stopping system modules
2022-12-17 21:05:36 Turning off a virtual drive
2022-12-17 21:05:36 Server has successfully stopped in 0,36 seconds!
Вот что в логах MariaDb:
2022-12-17 21:05:18 0 [Note] d:\portable\openserver-5.4.2\modules\database\MariaDB-10.6-Win10\bin\mysqld.exe (server 10.6.7-MariaDB-log) starting as process 19168 ...
2022-12-17 21:05:18 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2022-12-17 21:05:18 0 [Note] InnoDB: Number of pools: 1
2022-12-17 21:05:18 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2022-12-17 21:05:18 0 [Note] InnoDB: Initializing buffer pool, total size = 268435456, chunk size = 134217728
2022-12-17 21:05:18 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-17 21:05:18 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=217357417,217977452
2022-12-17 21:05:19 0 [ERROR] InnoDB: Missing FILE_CREATE, FILE_DELETE or FILE_MODIFY before FILE_CHECKPOINT for tablespace 1971
2022-12-17 21:05:19 0 [ERROR] InnoDB: Plugin initialization aborted with error Data structure corruption
2022-12-17 21:05:19 0 [Note] InnoDB: Starting shutdown...
2022-12-17 21:05:19 0 [ERROR] Plugin 'InnoDB' init function returned error.
2022-12-17 21:05:19 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2022-12-17 21:05:19 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-17 21:05:19 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2022-12-17 21:05:19 0 [ERROR] Aborting
Подскажите пожалуйста, как можно оживить базу с данными?
Увы, с помощью гугла не смог найти решения проблемы...
Заранее большое спасибо.
- Текущее время: 24 сен 2026, 13:29
