Your requirements could not be resolved to an installable set of packages.
Problem 1
- league/flysystem 1.1.9 requires ext-fileinfo * -> it is missing from your system. Install or enable PHP's fileinfo extension.
- laravel/framework v8.83.19 requires league/flysystem ^1.1 -> satisfiable by league/flysystem[1.1.9].
- laravel/framework is locked to version v8.83.19 and an update of this package was not requested.
To enable extensions, verify that they are enabled in your .ini files:
- C:\PHP\php.ini
You can also run `php --ini` in a terminal to see which files are used by PHP in CLI mode.
Alternatively, you can run Composer with `--ignore-platform-req=ext-fileinfo` to temporarily ignore these required extensions.
You can also try re-running composer require with an explicit version constraint, e.g. "composer require tcg/voyager:*" to figure out if any version is installable, or "composer require tcg/voyager:^2.1" if you know which you need.
- Текущее время: 17 ноя 2026, 20:55
