composer require spatie/image Warning: This development build of composer is over 60 days old. It is recommend ed to update it by running "d:\openserv3\ospanel\modules\php\PHP-7.2\composer.ph ar self-update" to get the latest version. Using version ^1.7 for spatie/image ./composer.json has been updated Loading composer repositories with package information Updating dependencies (including require-dev) VirtualAlloc() failed: [0x00000008] ������������ ������ ��� ��������� �������. VirtualFree() failed: [0x000001e7] ������� ��������� � ��������� ������. VirtualAlloc() failed: [0x00000008] ������������ ������ ��� ��������� �������. VirtualFree() failed: [0x000001e7] ������� ��������� � ��������� ������. Fatal error: Out of memory (allocated 1063256064) (tried to allocate 117440512 b ytes) in phar://D:/OPENSERV3/OSPanel/modules/php/PHP-7.2/composer.phar/src/Compo ser/DependencyResolver/RuleSet.php on line 90В пхп ини поставил лимит, в инфо выдаёт
memory_limit 100000000000000MB
Сам пхп версии 7.2
