Теперь пересобираю nginx с нужными мне модулями:
Nginx 1.10.3 собран со всеми стандартными модулями, плюс добавил модули: RTMP, Progress upload, FLV, MP4.
./configure --with-cc-opt='-g -O2 -fPIE -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2' --with-ld-opt='-Wl,-Bsymbolic-functions -fPIE -pie -Wl,-z,relro -Wl,-z,now' --prefix=/usr/share/nginx --conf-path=/etc/nginx/nginx.conf --http-log-path=/var/log/nginx/access.log --error-log-path=/var/log/nginx/error.log --lock-path=/var/lock/nginx.lock --pid-path=/run/nginx.pid --http-client-body-temp-path=/var/lib/nginx/body --http-fastcgi-temp-path=/var/lib/nginx/fastcgi --http-proxy-temp-path=/var/lib/nginx/proxy --http-scgi-temp-path=/var/lib/nginx/scgi --http-uwsgi-temp-path=/var/lib/nginx/uwsgi --with-debug --with-pcre-jit --with-ipv6 --with-http_ssl_module --with-http_stub_status_module --with-http_realip_module --with-http_auth_request_module --with-http_addition_module --with-http_dav_module --with-http_geoip_module --with-http_gunzip_module --with-http_gzip_static_module --with-http_image_filter_module --with-http_v2_module --with-http_sub_module --with-http_xslt_module --with-stream --with-stream_ssl_module --with-mail --with-mail_ssl_module --with-threads --with-http_mp4_module --with-http_flv_module --add-module=/home/odmin/nginx-rtmp-module-master --add-module=/home/odmin/nginx-upload-progress-module-masterВ конфиге nginx.conf добавил:
rtmp {
server {
application vidbase {
play /var/www/;
Однако при старте выдает ошибку, ругается на вставленный в конфиг код: RTMProot@VIDEOPNZ:~# service nginx start
Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
(Вот этот код)
root@VIDEOPNZ:~# systemctl status nginx.service journalctl ? nginx.service - A high performance web server and a reverse proxy server Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Пт 2019-03-29 12:39:11 MSK; 58s ago Process: 28335 ExecStop=/sbin/start-stop-daemon --quiet --stop --retry QUIT/5 --pidfile /run/nginx.pid (code=exited, status=0/SUCCESS) Process: 28236 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS) Process: 29430 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE) Main PID: 28238 (code=exited, status=0/SUCCESS) мар 29 12:39:11 VIDEOPNZ systemd[1]: Starting A high performance web server and a reverse proxy server... мар 29 12:39:11 VIDEOPNZ nginx[29430]: nginx: [emerg] unknown directive "rtmp" in /etc/nginx/nginx.conf:10 мар 29 12:39:11 VIDEOPNZ nginx[29430]: nginx: configuration file /etc/nginx/nginx.conf test failed мар 29 12:39:11 VIDEOPNZ systemd[1]: nginx.service: Control process exited, code=exited status=1 мар 29 12:39:11 VIDEOPNZ systemd[1]: Failed to start A high performance web server and a reverse proxy server. мар 29 12:39:11 VIDEOPNZ systemd[1]: nginx.service: Unit entered failed state. мар 29 12:39:11 VIDEOPNZ systemd[1]: nginx.service: Failed with result 'exit-code'. ? journalctl.service Loaded: not-found (Reason: No such file or directory) Active: inactive (dead)При этом сам nginx собрался (make, make install) без ошибок совершенно.
В чем может быть проблема?
Я уже сдаюсь, прошу помощи знающих людей.
