Добрый день всем форумчанам!
При попытке запустить сайт (DLE) на чистом Nginx 1.14 в лог Nginx в режиме дебагера стал получать ошибки пути такого вида - "e:\ospanel\modules\http\Nginx-1.14/htmluploads/sitemap.xml"
Вот кусок лога:
2018/11/22 12:47:02 [notice] 9424#3556: *1 "^/rss.xml$" does not match "/sitemap.xml", client: 127.0.0.1, server: site.ru, request: "GET /sitemap.xml HTTP/2.0", host: "site.ru"
2018/11/22 12:47:02 [debug] 9424#3556: *1 http script regex: "^/sitemap.xml$"
2018/11/22 12:47:02 [notice] 9424#3556: *1 "^/sitemap.xml$" matches "/sitemap.xml", client: 127.0.0.1, server: site.ru, request: "GET /sitemap.xml HTTP/2.0", host: "site.ru"
2018/11/22 12:47:02 [debug] 9424#3556: *1 http script copy: "uploads/sitemap.xml"
2018/11/22 12:47:02 [debug] 9424#3556: *1 http script regex end
2018/11/22 12:47:02 [notice] 9424#3556: *1 rewritten data: "uploads/sitemap.xml", args: "", client: 127.0.0.1, server: site.ru, request: "GET /sitemap.xml HTTP/2.0", host: "site.ru"
2018/11/22 12:47:02 [debug] 9424#3556: *1 post rewrite phase: 4
2018/11/22 12:47:02 [debug] 9424#3556: *1 uri changes: 11
2018/11/22 12:47:02 [debug] 9424#3556: *1 test location: "/"
2018/11/22 12:47:02 [debug] 9424#3556: *1 test location: ~ "/\."
2018/11/22 12:47:02 [debug] 9424#3556: *1 test location: ~ "\.php$"
2018/11/22 12:47:02 [debug] 9424#3556: *1 using configuration ""
2018/11/22 12:47:02 [debug] 9424#3556: *1 http cl:-1 max:52428800
2018/11/22 12:47:02 [debug] 9424#3556: *1 rewrite phase: 3
2018/11/22 12:47:02 [debug] 9424#3556: *1 generic phase: 5
2018/11/22 12:47:02 [debug] 9424#3556: *1 generic phase: 6
2018/11/22 12:47:02 [debug] 9424#3556: *1 generic phase: 7
2018/11/22 12:47:02 [debug] 9424#3556: *1 access phase: 8
2018/11/22 12:47:02 [debug] 9424#3556: *1 access phase: 9
2018/11/22 12:47:02 [debug] 9424#3556: *1 access phase: 10
2018/11/22 12:47:02 [debug] 9424#3556: *1 post access phase: 11
2018/11/22 12:47:02 [debug] 9424#3556: *1 generic phase: 12
2018/11/22 12:47:02 [debug] 9424#3556: *1 generic phase: 13
2018/11/22 12:47:02 [debug] 9424#3556: *1 content phase: 14
2018/11/22 12:47:02 [debug] 9424#3556: *1 content phase: 15
2018/11/22 12:47:02 [debug] 9424#3556: *1 content phase: 16
2018/11/22 12:47:02 [debug] 9424#3556: *1 content phase: 17
2018/11/22 12:47:02 [debug] 9424#3556: *1 content phase: 18
2018/11/22 12:47:02 [debug] 9424#3556: *1 content phase: 19
2018/11/22 12:47:02 [debug] 9424#3556: *1 http filename: "e:\ospanel\modules\http\Nginx-1.14/htmluploads/sitemap.xml"
2018/11/22 12:47:02 [debug] 9424#3556: *1 add cleanup: 02E2CA68
2018/11/22 12:47:02 [error] 9424#3556: *1 CreateFile() "e:\ospanel\modules\http\Nginx-1.14/htmluploads/sitemap.xml" failed (3: The system cannot find the path specified), client: 127.0.0.1, server: site.ru, request: "GET /sitemap.xml HTTP/2.0", host: "site.ru"
2018/11/22 12:47:02 [debug] 9424#3556: *1 http finalize request: 404, "uploads/sitemap.xml?" a:1, c:1
2018/11/22 12:47:02 [debug] 9424#3556: *1 http special response: 404, "uploads/sitemap.xml?"
Где Nginx берет этот путь файла? Это ошибка Nginx или где-то я накосячил с настройками?
Буду благодарен за любую помощь!
Да, забыл добавить - версия PHP - 5.6-X64
- Текущее время: 11 авг 2026, 06:57
