<?php
$connection = mysqli_connect(`127.0.0.1`, `root`, `facer`, `common_db`);
if ($connection == false)
	echo 'Connection was been lost. Try to repair!<br>';
	echo mysqli_connect_error();
	exit();
else
	echo 'Congratulations, all will be good!';
Вот Ошибка!Warning: mysqli_connect(): (HY000/1045): Access denied for user ''@'localhost' (using password: NO) in C:\OpenServer\domains\first.ru\index.php on line 3 Connection was been lost. Try to repair! Access denied for user ''@'localhost' (using password: NO)Пытался убирать пароль и оставлять только $connection = mysqli_connect(`127.0.0.1`, `root`, ``, `common_db`); не помогло. Пароль facer 100% ставил сам.
