лог mysql отладки
170208 3:35:56 [Note] e:\openserver2\modules\database\MySQL-5.5\bin\mysqld.exe (mysqld 5.5.50-log) starting as process 5828 ... 170208 3:35:56 [Note] Plugin 'FEDERATED' is disabled. 170208 3:35:56 InnoDB: The InnoDB memory heap is disabled 170208 3:35:56 InnoDB: Mutexes and rw_locks use Windows interlocked functions 170208 3:35:56 InnoDB: Compressed tables use zlib 1.2.3 170208 3:35:56 InnoDB: Initializing buffer pool, size = 128.0M 170208 3:35:56 InnoDB: Completed initialization of buffer pool 170208 3:35:56 InnoDB: highest supported file format is Barracuda. 170208 3:35:58 InnoDB: Waiting for the background threads to start 170208 3:35:59 InnoDB: 5.5.50 started; log sequence number 37064673 170208 3:35:59 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306 170208 3:35:59 [Note] - '127.0.0.1' resolves to '127.0.0.1'; 170208 3:35:59 [Note] Server socket created on IP: '127.0.0.1'. 170208 3:35:59 [ERROR] Column count of mysql.db is wrong. Expected 22, found 20. The table is probably corrupted 170208 3:35:59 [ERROR] mysql.user has no `Event_priv` column at position 29 170208 3:35:59 [ERROR] Event Scheduler: An error occurred when initializing system tables. Disabling the Event Scheduler. 170208 3:35:59 [Note] e:\openserver2\modules\database\MySQL-5.5\bin\mysqld.exe: ready for connections. Version: '5.5.50-log' socket: '' port: 3306 MySQL Community Server (GPL)встроенная хайди пишет: Access denied for user 'root'@'localhost' (using password: NO)
Пароль никогда не ставила, заходила всегда под рутом.
Как мне вытащить базы теперь оттуда?
