1. Установил PECL.
2. Сконфигурировал
конфиг:
> pear config-show CONFIGURATION (CHANNEL PEAR.PHP.NET): ===================================== Auto-discover new Channels auto_discover 1 Default Channel default_channel pear.php.net HTTP Proxy Server Address http_proxy <not set> PEAR server [DEPRECATED] master_server pear.php.net Default Channel Mirror preferred_mirror pear.php.net Remote Configuration File remote_config <not set> PEAR executables directory bin_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR PEAR documentation directory doc_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\docs PHP extension directory ext_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\ext PEAR directory php_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\pear PEAR Installer cache directory cache_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\cache PEAR configuration file cfg_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\cfg directory PEAR data directory data_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\data PEAR Installer download download_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\tmp directory Systems manpage files man_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\man directory PEAR metadata directory metadata_dir <not set> PHP CLI/CGI binary php_bin C:\OpenServer\modules\php\PHP-7-x64\php.exe php.ini location php_ini C:\OpenServer\modules\php\PHP-7-x64\php.ini --program-prefix passed to php_prefix <not set> PHP's ./configure --program-suffix passed to php_suffix <not set> PHP's ./configure PEAR Installer temp directory temp_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\tmp PEAR test directory test_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\tests PEAR www files directory www_dir C:\OpenServer\modules\php\PHP-7-x64\PEAR\www Cache TimeToLive cache_ttl 3600 Preferred Package State preferred_state stable Unix file mask umask 0 Debug Log Level verbose 1 PEAR password (for password <not set> maintainers) Signature Handling Program sig_bin C:\OpenServer\modules\php\PHP-7-x64\gnupg\gpg.exe Signature Key Directory sig_keydir C:\OpenServer\modules\php\PHP-7-x64\PEAR\pearkeys Signature Key Id sig_keyid <not set> Package Signature Type sig_type gpg PEAR username (for username <not set> maintainers) User Configuration File Filename c:\openserver\modules\php\PHP-7-x64\PEAR\pear.ini System Configuration File Filename c:\openserver\modules\php\PHP-7-x64\PEAR\pearsys.ini3. Выполняю команду
Aleksey@ALEKSEY-PC c:\openserver > pecl list-all Connection to `ssl://pecl.php.net:443' failed: Unable to find the socket transport "ssl" - did you forget to enable it when you configured PHP?Дает ошибку SSL
SSL в конфиге php включен.
Что я делаю не так?
P.S. Пакеты тоже в упор не замечает
Aleksey@ALEKSEY-PC c:\openserver > pecl install raphf No releases available for package "pecl.php.net/raphf" install failed Aleksey@ALEKSEY-PC c:\openserver > pecl install propro No releases available for package "pecl.php.net/propro" install failed Aleksey@ALEKSEY-PC c:\openserver > pecl install pecl_http No releases available for package "pecl.php.net/pecl_http" install failed
