2016-05-24 23:21:01 0 [Note] e:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe (mysqld 5.6.26-log) starting as process 4140 ... 2016-05-24 23:21:01 4140 [Note] Plugin 'FEDERATED' is disabled. 2016-05-24 23:21:01 4140 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-05-24 23:21:01 4140 [Note] InnoDB: The InnoDB memory heap is disabled 2016-05-24 23:21:01 4140 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-05-24 23:21:01 4140 [Note] InnoDB: Memory barrier is not used 2016-05-24 23:21:01 4140 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-05-24 23:21:01 4140 [Note] InnoDB: Not using CPU crc32 instructions 2016-05-24 23:21:01 4140 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-05-24 23:21:01 4140 [Note] InnoDB: Completed initialization of buffer pool 2016-05-24 23:21:01 4140 [Note] InnoDB: Highest supported file format is Barracuda. 2016-05-24 23:21:01 4140 [Note] InnoDB: The log sequence numbers 6438369948 and 6438369948 in ibdata files do not match the log sequence number 6438369978 in the ib_logfiles! 2016-05-24 23:21:01 4140 [Note] InnoDB: Database was not shutdown normally! 2016-05-24 23:21:01 4140 [Note] InnoDB: Starting crash recovery. 2016-05-24 23:21:01 4140 [Note] InnoDB: Reading tablespace information from the .ibd files... 2016-05-24 23:21:07 4140 [Note] InnoDB: Restoring possible half-written data pages 2016-05-24 23:21:07 4140 [Note] InnoDB: from the doublewrite buffer... 2016-05-24 23:21:09 4140 [Note] InnoDB: 128 rollback segment(s) are active. 2016-05-24 23:21:09 4140 [Note] InnoDB: Waiting for purge to start 2016-05-24 23:21:10 4140 [Note] InnoDB: 5.6.26 started; log sequence number 6438369978 2016-05-24 23:21:10 4140 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306 2016-05-24 23:21:10 4140 [Note] - '127.0.0.1' resolves to '127.0.0.1'; 2016-05-24 23:21:10 4140 [Note] Server socket created on IP: '127.0.0.1'. 2016-05-24 23:21:10 4140 [Note] Event Scheduler: Loaded 0 events 2016-05-24 23:21:10 4140 [Note] e:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: ready for connections. Version: '5.6.26-log' socket: '' port: 3306 MySQL Community Server (GPL)не понимаю что произошло, раньше всё работало
- Текущее время: 10 ноя 2026, 09:54
