- Текущее время: 27 сен 2026, 05:48
Microsoft Windows [Version 6.1.7601]
ХХХХХХХХХ@ХХХХХХХХХ-ПК c:\openserver
$ cd domains
ХХХХХХХХХ@ХХХХХХХХХ-ПК c:\OpenServer\domains
$ cd LaravelTest.ru
ХХХХХХХХХ@ХХХХХХХХХ-ПК c:\OpenServer\domains\LaravelTest.ru
$ php -r "readfile('https://getcomposer.org/installer');" > composer-setup.php
ХХХХХХХХХ@ХХХХХХХХХ c:\OpenServer\domains\LaravelTest.ru
$ php -r "if (hash_file('SHA384', 'composer-setup.php') === '7228c001f88bee97506740ef0888240bd8a760b046ee16db8f4095c0d8d525f2367663f22a46b48d072c816e7fe19959') { echo 'Installer verified'; } else { echo 'Installer corrupt'; unlink('composer-setup.php'); } echo PHP_EOL;"
Installer verified
$ php composer-setup.php
All settings correct for using Composer
Warning: file_get_contents(): SSL operation failed with code 1. OpenSSL Error messages:
error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed in C:\OpenServer\domains\LaravelTest.ru\composer-setup.php on line 664
Warning: file_get_contents(): Failed to enable crypto in C:\OpenServer\domains\LaravelTest.ru\composer-setup.php on line 664
Warning: file_get_contents(https://getcomposer.org/versions): failed to open stream: operation failed in C:\OpenServer\domains\LaravelTest.ru\composer-setup.php on line 664
Warning: Invalid argument supplied for foreach() in C:\OpenServer\domains\LaravelTest.ru\composer-setup.php on line 447
Fatal error: Uncaught exception 'RuntimeException' with message 'There is no version of Composer available for your PHP version (5.5.33)' in C:\OpenServer\domains\LaravelTest.ru\composer-setup.php:456
Stack trace:
#0 C:\OpenServer\domains\LaravelTest.ru\composer-setup.php(112): installComposer(false, false, 'composer.phar', false, false, false, 'stable')
#1 C:\OpenServer\domains\LaravelTest.ru\composer-setup.php(13): process(Array)
#2 {main}
thrown in C:\OpenServer\domains\LaravelTest.ru\composer-setup.php on line 456
Помогите разобраться, а то я только учусь.php -r "readfile('https://getcomposer.org/installer');" | php - обязательно проследить перед <r> наличие тире, а не дефиса) и далее после установки композера обновить: composer self-update и у меня композер встал на место.Warning: file_get_contents(): SSL operation failed with code 1. OpenSSL Error messages: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed in - on line 664
Warning: file_get_contents(): Failed to enable crypto in - on line 664
Warning: file_get_contents(https://getcomposer.org/versions): failed to open stream: operation failed in - on line 664
Warning: Invalid argument supplied for foreach() in - on line 447
Fatal error: Uncaught exception 'RuntimeException' with message 'There is no version of Composer available for your PHP version (5.5.33)' in -:456
Stack trace:
#0 -(112): installComposer(false, false, 'composer.phar', false, false, false, 'stable')
#1 -(13): process(Array)
#2 {main}
thrown in - on line 456
Может я до этого, что-то не так делаю?
