160316 22:03:25 [Note] h:\openserver\modules\database\MySQL-5.5\bin\mysqld.exe (mysqld 5.5.45) starting as process 4408 ... 160316 22:03:26 [Note] Plugin 'FEDERATED' is disabled. 160316 22:03:26 InnoDB: The InnoDB memory heap is disabled 160316 22:03:26 InnoDB: Mutexes and rw_locks use Windows interlocked functions 160316 22:03:26 InnoDB: Compressed tables use zlib 1.2.3 160316 22:03:26 InnoDB: Initializing buffer pool, size = 20.0M 160316 22:03:26 InnoDB: Completed initialization of buffer pool 160316 22:03:26 InnoDB: highest supported file format is Barracuda. 160316 22:03:26 InnoDB: Waiting for the background threads to start 160316 22:03:27 InnoDB: 5.5.45 started; log sequence number 1595675 160316 22:03:27 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306 160316 22:03:27 [Note] - '127.0.0.1' resolves to '127.0.0.1'; 160316 22:03:27 [Note] Server socket created on IP: '127.0.0.1'. 160316 22:03:28 [Note] Event Scheduler: Loaded 0 events 160316 22:03:28 [Note] h:\openserver\modules\database\MySQL-5.5\bin\mysqld.exe: ready for connections. Version: '5.5.45' socket: '' port: 3306 MySQL Community Server (GPL)apache отладка
[Wed Mar 16 22:03:27 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:27 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:27 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:27 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Mar 16 22:03:28 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:28 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:28 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:28 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Mar 16 22:03:32 2016] [notice] Apache/2.2.31 (Win32) mod_ssl/2.2.31 OpenSSL/1.0.1p configured -- resuming normal operations [Wed Mar 16 22:03:32 2016] [notice] Server built: Jul 16 2015 11:30:50 [Wed Mar 16 22:03:32 2016] [notice] Parent: Created child process 4092 [Wed Mar 16 22:03:32 2016] [notice] Disabled use of AcceptEx() WinSock2 API [Wed Mar 16 22:03:32 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:32 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:32 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:32 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Mar 16 22:03:33 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:33 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:33 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:33 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Mar 16 22:03:33 2016] [notice] Child 4092: Child process is running [Wed Mar 16 22:03:33 2016] [notice] Child 4092: Acquired the start mutex. [Wed Mar 16 22:03:33 2016] [notice] Child 4092: Starting 32 worker threads. [Wed Mar 16 22:03:33 2016] [notice] Child 4092: Listening on port 443. [Wed Mar 16 22:03:33 2016] [notice] Child 4092: Listening on port 80. [Wed Mar 16 22:03:49 2016] [notice] Parent: child process exited with status 3221226356 -- Restarting. [Wed Mar 16 22:03:50 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:50 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:50 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:50 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Mar 16 22:03:51 2016] [notice] Apache/2.2.31 (Win32) mod_ssl/2.2.31 OpenSSL/1.0.1p configured -- resuming normal operations [Wed Mar 16 22:03:51 2016] [notice] Server built: Jul 16 2015 11:30:50 [Wed Mar 16 22:03:51 2016] [notice] Parent: Created child process 5072 [Wed Mar 16 22:03:51 2016] [notice] Disabled use of AcceptEx() WinSock2 API [Wed Mar 16 22:03:51 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:51 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:51 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:51 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Mar 16 22:03:52 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:52 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:52 2016] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Wed Mar 16 22:03:52 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Mar 16 22:03:52 2016] [notice] Child 5072: Child process is running [Wed Mar 16 22:03:52 2016] [notice] Child 5072: Acquired the start mutex. [Wed Mar 16 22:03:52 2016] [notice] Child 5072: Starting 32 worker threads. [Wed Mar 16 22:03:52 2016] [notice] Child 5072: Listening on port 443. [Wed Mar 16 22:03:52 2016] [notice] Child 5072: Listening on port 80.
