переименовал его в my.ini, и сейчас выдает вот это.
2016-03-14T18:45:29.136823Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). 2016-03-14T18:45:29.136823Z 0 [Warning] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release. 2016-03-14T18:45:29.136823Z 0 [Warning] 'NO_AUTO_CREATE_USER' sql mode was not set. 2016-03-14T18:45:29.136823Z 0 [Warning] Insecure configuration for --secure-file-priv: Current value does not restrict location of generated files. Consider setting it to a valid, non-empty path. 2016-03-14T18:45:29.136823Z 0 [Note] c:\openserver\modules\database\MySQL-5.7\bin\mysqld.exe (mysqld 5.7.10) starting as process 2444 ... 2016-03-14T18:45:29.145824Z 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-03-14T18:45:29.145824Z 0 [Note] InnoDB: Uses event mutexes 2016-03-14T18:45:29.145824Z 0 [Note] InnoDB: _mm_lfence() and _mm_sfence() are used for memory barrier 2016-03-14T18:45:29.145824Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-03-14T18:45:29.146824Z 0 [Note] InnoDB: Number of pools: 1 2016-03-14T18:45:29.146824Z 0 [Note] InnoDB: Not using CPU crc32 instructions 2016-03-14T18:45:29.183826Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M 2016-03-14T18:45:29.197827Z 0 [Note] InnoDB: Completed initialization of buffer pool 2016-03-14T18:45:29.270831Z 0 [Note] InnoDB: Highest supported file format is Barracuda. 2016-03-14T18:45:29.442841Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables 2016-03-14T18:45:29.443841Z 0 [Note] InnoDB: Setting file '.\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ... 2016-03-14T18:45:30.031874Z 0 [Note] InnoDB: File '.\ibtmp1' size is now 12 MB. 2016-03-14T18:45:30.035875Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active. 2016-03-14T18:45:30.035875Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active. 2016-03-14T18:45:30.036875Z 0 [Note] InnoDB: Waiting for purge to start 2016-03-14T18:45:30.094878Z 0 [Note] InnoDB: 5.7.10 started; log sequence number 1209961 2016-03-14T18:45:30.095878Z 0 [Note] InnoDB: Loading buffer pool(s) from c:\openserver\modules\database\MySQL-5.7\data\ib_buffer_pool 2016-03-14T18:45:30.095878Z 0 [Note] InnoDB: not started 2016-03-14T18:45:30.095878Z 0 [Note] Plugin 'FEDERATED' is disabled. mysqld: Table 'mysql.plugin' doesn't exist 2016-03-14T18:45:30.096878Z 0 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it. 2016-03-14T18:45:30.096878Z 0 [Note] InnoDB: Buffer pool(s) load completed at 160314 23:45:30 2016-03-14T18:45:30.096878Z 0 [Warning] Gtid table is not ready to be used. Table 'mysql.gtid_executed' cannot be opened. 2016-03-14T18:45:30.097878Z 0 [Warning] Failed to set up SSL because of the following SSL library error: SSL context is not usable without certificate and private key 2016-03-14T18:45:30.098878Z 0 [Note] Server hostname (bind-address): '*'; port: 3306 2016-03-14T18:45:30.098878Z 0 [Note] IPv6 is available. 2016-03-14T18:45:30.099878Z 0 [Note] - '::' resolves to '::'; 2016-03-14T18:45:30.099878Z 0 [Note] Server socket created on IP: '::'. 2016-03-14T18:45:30.101878Z 0 [Warning] Failed to open optimizer cost constant tables 2016-03-14T18:45:30.102878Z 0 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.user' doesn't exist 2016-03-14T18:45:30.102878Z 0 [ERROR] Aborting 2016-03-14T18:45:30.102878Z 0 [Note] Binlog end 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'ngram' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'partition' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'BLACKHOLE' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'ARCHIVE' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'MRG_MYISAM' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'MyISAM' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_VIRTUAL' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_FIELDS' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_INDEXES' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLES' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_FT_CONFIG' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_FT_DELETED' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_METRICS' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_TEMP_TABLE_INFO' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_CMP_RESET' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_CMP' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_LOCK_WAITS' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_LOCKS' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'INNODB_TRX' 2016-03-14T18:45:30.102878Z 0 [Note] Shutting down plugin 'InnoDB' 2016-03-14T18:45:30.102878Z 0 [Note] InnoDB: FTS optimize thread exiting. 2016-03-14T18:45:30.102878Z 0 [Note] InnoDB: Starting shutdown... 2016-03-14T18:45:30.202884Z 0 [Note] InnoDB: Dumping buffer pool(s) to c:\openserver\modules\database\MySQL-5.7\data\ib_buffer_pool 2016-03-14T18:45:30.205884Z 0 [Note] InnoDB: Buffer pool(s) dump completed at 160314 23:45:30 2016-03-14T18:45:31.508959Z 0 [Note] InnoDB: Shutdown completed; log sequence number 1209980 2016-03-14T18:45:31.508959Z 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1" 2016-03-14T18:45:31.508959Z 0 [Note] Shutting down plugin 'MEMORY' 2016-03-14T18:45:31.508959Z 0 [Note] Shutting down plugin 'CSV' 2016-03-14T18:45:31.508959Z 0 [Note] Shutting down plugin 'sha256_password' 2016-03-14T18:45:31.508959Z 0 [Note] Shutting down plugin 'mysql_native_password' 2016-03-14T18:45:31.509959Z 0 [Note] Shutting down plugin 'binlog' 2016-03-14T18:45:31.509959Z 0 [Note] c:\openserver\modules\database\MySQL-5.7\bin\mysqld.exe: Shutdown completeПодскажите в чем ошибка или нельзя ставить?
