  Open Server скачали уже 1 475 938 раз!
Установка PEAR
Semihal
C нами: 1 год 11 мес
Непрочитанное сообщение Semihal » 12 мар 2016, 17:43
При запуске
php.exe -d output_buffering=0 PEAR\go-pear.phar
Славливаю:
S:\Program Files (x86)\Open server\OpenServer\modules\php\PHP-5.6>php.exe -d output_buffering=0 go-pear.phar
Failed loading w:/modules/php/PHP-5.6/ext/php_ioncube.dll
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_mbstring.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
 in Unknown on line 0
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_bz2.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_curl.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_exif.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_fileinfo.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_gd2.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_gettext.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_igbinary.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_imagick.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_imap.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_memcache.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_mongo.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_mysql.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_mysqli.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_openssl.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_pdflib.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_pdo_mysql.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_pdo_pgsql.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_pdo_sqlite.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_redis.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_soap.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_sockets.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_sqlite3.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_timezonedb.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_xmlrpc.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
PHP Warning:  PHP Startup: Unable to load dynamic library 'w:/modules/php/PHP-5.6/ext/php_xsl.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
Could not open input file: go-pear.phar
S:\Program Files (x86)\Open server\OpenServer\modules\php\PHP-5.6>php.exe -d output_buffering=0 PEAR\go-pear.phar
PHP Warning:  Unknown: open_basedir restriction in effect. File(PEAR\go-pear.phar) is not within the allowed path(s): (w:/domains;w:/userdata/temp;w:/modules/system/html/openserver;w:/modules/php/PHP-5.6) in Unknown on line 0
PHP Warning:  Phar::mapPhar(): open_basedir restriction in effect. File(S:\Program Files (x86)\Open server\OpenServer\modules\php\PHP-5.6\PEAR\go-pear.phar) is not within the allowed path(s): (w:/domains;w:/userdata/temp;w:/modules/system/html/openserver;w:/modules/php/PHP-5.6) in S:\Program Files (x86)\Open server\OpenServer\modules\php\PHP-5.6\PEAR\go-pear.phar on line 1119
PHP Warning:  require_once(): open_basedir restriction in effect. File(go-pear.phar) is not within the allowed path(s): (w:/domains;w:/userdata/temp;w:/modules/system/html/openserver;w:/modules/php/PHP-5.6) in S:\Program Files (x86)\Open server\OpenServer\modules\php\PHP-5.6\PEAR\go-pear.phar on line 1236
PHP Warning:  require_once(): open_basedir restriction in effect. File(go-pear.phar/index.php) is not within the allowed path(s): (w:/domains;w:/userdata/temp;w:/modules/system/html/openserver;w:/modules/php/PHP-5.6) in S:\Program Files (x86)\Open server\OpenServer\modules\php\PHP-5.6\PEAR\go-pear.phar on line 1236
PHP Warning:  require_once(phar://go-pear.phar/index.php): failed to open stream: phar error: invalid url or non-existent phar "phar://go-pear.phar/index.php" in S:\Program Files (x86)\Open server\OpenServer\modules\php\PHP-5.6\PEAR\go-pear.phar on line 1236
Что делать?
Semihal
Непрочитанное сообщение Semihal » 12 мар 2016, 18:06
Почему он долбится на диск w:/ ?? В настройках его нигде нет, сам же он его не монтирует. Какого...?
Asmodey
C нами: 5 лет 10 мес
Непрочитанное сообщение Asmodey » 12 мар 2016, 18:58
Видимо, виртуальный диск. Где-то мелькало, что оно надо для корректного запуска мускула (он прочно не дружит с путями определённого вида).
Semihal
Непрочитанное сообщение Semihal » 12 мар 2016, 20:45
Да, прочитал на форуме, что не под всеми пользаками его видно, через тотал увидел. Странно, сижу из под админа...
Но проблема с "потерянными" файлами остается все та же :( Он не подключает их. Пир установить нормально так и не смог.
Теперь пишет при "pear" из cmd:
Warning: PHP Startup: Unable to load dynamic library 'z:/modules/php/PHP-5.6/ext/php_imagick.dll' - ═х эрщфхэ єърчрээ√щ ьюфєы№.
А если запускать через ConEmul из закладок, тогда там целый список таких ошибок, даже при
php -v
C нами: 7 лет 2 мес
Непрочитанное сообщение Максим » 22 мар 2016, 17:23
Semihal, нужно открыть встроенную консоль после запуска сервера и выполнить команду: go-pear
Semihal писал(а):А если запускать через ConEmul из закладок, тогда там целый список таких ошибок
Вот и покажите что у вас за ошибки. Сообщите версию Open Server.
