PHP.INI - max_input_vars ?
pro_vitaly
07 фев 2016, 23:28
pro_vitaly » 07 фев 2016, 23:35
Как в файле php.ini изменить max_input_vars ?
Меню - Дополнительно - Конфигурация
не могу найти такой строки...
[PHP]
; Name for user-defined php.ini (.htaccess) files. Default is ".user.ini"
;user_ini.filename = ".user.ini"
;user_ini.cache_ttl = 300
engine = On
zend.ze1_compatibility_mode = Off
short_open_tag = On
asp_tags = Off
precision = 12
y2k_compliance = On
output_buffering = off
;output_handler =
zlib.output_compression = Off
;zlib.output_compression_level = -1
;zlib.output_handler =
implicit_flush = Off
unserialize_callback_func=
serialize_precision = 100
allow_call_time_pass_reference = Off
safe_mode = Off
safe_mode_gid = Off
safe_mode_include_dir =
safe_mode_exec_dir =
safe_mode_allowed_env_vars = PHP_
safe_mode_protected_env_vars = LD_LIBRARY_PATH
; Установка защиты от внешнего доступа
; См. Руководство Пользователя: Защита сервера
%disallow%open_basedir = "%ssitedir%;%sprogdir%/userdata/temp;%sprogdir%/modules/system/html/openserver;%sprogdir%/modules/php/%phpdriver%"
%disallow%disable_functions = exec,system,shell_exec,passthru,popen,pclose,dl,apache_note,apache_setenv,define_syslog_variables,pcntl_exec,syslog,posix_kill,posix_mkfifo,posix_setpgid,posix_setsid,posix_setuid,posix_setgid,apache_child_terminate,posix_getpwuid
disable_classes =
ignore_user_abort = Off
realpath_cache_size=2048k
realpath_cache_ttl=600
expose_php = Off
magic_quotes_gpc = Off
max_execution_time = 180     ; Maximum execution time of each script, in seconds
max_input_time = 180	; Maximum amount of time each script may spend parsing request data
;max_input_nesting_level = 64 ; Maximum input variable nesting level
memory_limit = 1536M
error_reporting = E_ALL & ~E_NOTICE | E_STRICT
display_errors = On
display_startup_errors = On
log_errors = On
log_errors_max_len = 9024
ignore_repeated_errors = Off
ignore_repeated_source = Off
report_memleaks = Off
;report_zend_debug = 0
track_errors = On
;xmlrpc_errors = 0
;xmlrpc_error_number = 0
;html_errors = Off
;docref_root = "/phpmanual/"
;docref_ext = .html
;error_prepend_string = "<font color=#ff0000>"
;error_append_string = "</font>"
error_log = "%sprogdir%/userdata/logs/%phpdriver%_error.log"
;error_log = syslog
;arg_separator.output = "&"
;arg_separator.input = ";&"
variables_order = "GPCS"
request_order = "GP"
register_globals = Off
register_argc_argv = On
auto_globals_jit = On
magic_quotes_runtime = Off
magic_quotes_sybase = Off
auto_prepend_file =
auto_append_file =
default_mimetype = "text/html"
;default_charset = "iso-8859-1"
;always_populate_raw_post_data = On
include_path = ".;%sprogdir%/modules/php/%phpdriver%;%sprogdir%/modules/php/%phpdriver%/PEAR/pear"
doc_root =
user_dir =
extension_dir = "%sprogdir%/modules/php/%phpdriver%/ext/"
enable_dl = Off
cgi.force_redirect = 0
cgi.fix_pathinfo=0
fastcgi.impersonate = 0
fastcgi.logging = 0
cgi.nph = 0
cgi.rfc2616_headers = 0
file_uploads = On
upload_tmp_dir = "%sprogdir%/userdata/temp/"
upload_max_filesize = 100M
post_max_size = 100M
max_file_uploads = 20
allow_url_fopen = On
allow_url_include = Off
default_socket_timeout = 60
; Define the anonymous ftp password (your email address)
;from="john@doe.com"
; Define the User-Agent string
; user_agent="PHP"
extension=php_mbstring.dll
extension=php_bz2.dll
extension=php_curl.dll
extension=php_enchant.dll
extension=php_exif.dll
extension=php_fileinfo.dll
extension=php_gd2.dll
extension=php_gettext.dll
;extension=php_gmp.dll
extension=php_igbinary.dll
extension=php_imap.dll
;extension=php_interbase.dll
;extension=php_intl.dll
;extension=php_ldap.dll
extension=php_memcache.dll
extension=php_mysql.dll
extension=php_mysqli.dll
;extension=php_oci8.dll      ; Use with Oracle 10gR2 Instant Client
;extension=php_oci8_11g.dll  ; Use with Oracle 11g Instant Client
extension=php_openssl.dll
extension=php_pdflib.dll
;extension=php_pdo_firebird.dll
extension=php_pdo_mysql.dll
;extension=php_pdo_oci.dll
;extension=php_pdo_odbc.dll
extension=php_pdo_pgsql.dll
extension=php_pdo_sqlite.dll
;extension=php_pgsql.dll
;extension=php_phalcon.dll
extension=php_redis.dll
;extension=php_shmop.dll
;extension=php_snmp.dll
extension=php_soap.dll
extension=php_sockets.dll
extension=php_sqlite.dll
extension=php_sqlite3.dll
;extension=php_sybase_ct.dll
;extension=php_tidy.dll
extension=php_timezonedb.dll
extension=php_xmlrpc.dll
extension=php_xsl.dll
[Date]
date.timezone = "Europe/Moscow"
[curl]
curl.cainfo = "%sprogdir%/modules/php/%phpdriver%/cacert.pem"
;date.default_latitude = 31.7667
;date.default_longitude = 35.2333
;date.sunrise_zenith = 90.583333
;date.sunset_zenith = 90.583333
[filter]
;filter.default = unsafe_raw
;filter.default_flags =
[iconv]
;iconv.input_encoding = ISO-8859-1
;iconv.internal_encoding = ISO-8859-1
;iconv.output_encoding = ISO-8859-1
[intl]
;intl.default_locale =
;intl.error_level = E_WARNING
[sqlite]
;sqlite.assoc_case = 0
[sqlite3]
;sqlite3.extension_dir =
[Pcre]
;pcre.backtrack_limit=100000
;pcre.recursion_limit=100000
[Pdo]
;pdo_odbc.connection_pooling=strict
;pdo_odbc.db2_instance_name
[Pdo_mysql]
pdo_mysql.cache_size = 2000
pdo_mysql.default_socket=
[Phar]
;phar.readonly = On
;phar.require_hash = On
;phar.cache_list =
[Syslog]
define_syslog_variables  = Off
[mail function]
;SMTP = localhost
;smtp_port = 25
; For Win32 only.
;sendmail_from = me@example.com
sendmail_path = "%mailway%"
; Force the addition of the specified parameters to be passed as extra parameters
; to the sendmail binary. These parameters will always replace the value of
; the 5th parameter to mail(), even in safe mode.
;mail.force_extra_parameters =
mail.add_x_header = On
; Log all mail() calls including the full path of the script, line #, to address and headers
;mail.log =
[SQL]
sql.safe_mode = Off
[ODBC]
;odbc.default_db    =  Not yet implemented
;odbc.default_user  =  Not yet implemented
;odbc.default_pw    =  Not yet implemented
;odbc.default_cursortype
odbc.allow_persistent = On
odbc.check_persistent = On
odbc.max_persistent = -1
odbc.max_links = -1
odbc.defaultlrl = 4096
odbc.defaultbinmode = 1
;birdstep.max_links = -1
[Interbase]
ibase.allow_persistent = 1
ibase.max_persistent = -1
ibase.max_links = -1
;ibase.default_db =
;ibase.default_user =
;ibase.default_password =
;ibase.default_charset =
ibase.timestampformat = "%Y-%m-%d %H:%M:%S"
ibase.dateformat = "%Y-%m-%d"
ibase.timeformat = "%H:%M:%S"
[MySQL]
mysql.allow_local_infile = On
mysql.allow_persistent = On
mysql.max_persistent = -1
mysql.max_links = -1
mysql.default_port = %mysqlport%
mysql.default_socket =
mysql.default_host =
mysql.default_user =
mysql.default_password =
mysql.connect_timeout = 60
mysql.trace_mode = Off
[MySQLi]
mysqli.max_persistent = -1
;mysqli.allow_local_infile = On
mysqli.allow_persistent = On
mysqli.max_links = -1
mysqli.cache_size = 2000
mysqli.default_port = %mysqlport%
mysqli.default_socket =
mysqli.default_host =
mysqli.default_user =
mysqli.default_pw =
; Allow or prevent reconnect
mysqli.reconnect = Off
[mysqlnd]
; http://php.net/mysqlnd.collect_statistics
mysqlnd.collect_statistics = On
mysqlnd.collect_memory_statistics = Off
; Size of a pre-allocated buffer used when sending commands to MySQL in bytes.
;mysqlnd.net_cmd_buffer_size = 2048
; Size of a pre-allocated buffer used for reading data sent by the server in bytes.
;mysqlnd.net_read_buffer_size = 32768
[OCI8]
;oci8.privileged_connect = Off
;oci8.max_persistent = -1
;oci8.persistent_timeout = -1
;oci8.ping_interval = 60
;oci8.statement_cache_size = 20
;oci8.default_prefetch = 100
;oci8.old_oci_close_semantics = Off
[PostgresSQL]
pgsql.allow_persistent = On
pgsql.auto_reset_persistent = Off
pgsql.max_persistent = -1
pgsql.max_links = -1
pgsql.ignore_notice = 0
pgsql.log_notice = 0
[Sybase-CT]
sybct.allow_persistent = On
sybct.max_persistent = -1
sybct.max_links = -1
sybct.min_server_severity = 10
sybct.min_client_severity = 10
;sybct.timeout=
;sybct.packet_size
;sybct.login_timeout=
;sybct.hostname=
;sybct.deadlock_retry_count=
[bcmath]
bcmath.scale = 0
[browscap]
;browscap = "%sprogdir%/modules/php/%phpdriver%/browscap.ini"
[Session]
session.save_handler = files
session.save_path = "%sprogdir%/userdata/temp/"
session.use_cookies = 1
;session.cookie_secure =
session.use_only_cookies = 1
session.name = PHPSESSID
session.auto_start = 0
session.cookie_lifetime = 0
session.cookie_path = /
session.cookie_domain =
session.cookie_httponly =
session.serialize_handler = php
session.gc_probability = 1
session.gc_divisor     = 1000
session.gc_maxlifetime = 3600
session.bug_compat_42 = 0
session.bug_compat_warn = 0
session.referer_check =
session.entropy_length = 0
session.entropy_file =
;session.entropy_length = 16
;session.entropy_file = /dev/urandom
session.cache_limiter = nocache
session.cache_expire = 180
session.use_trans_sid = 0
session.hash_function = 0
session.hash_bits_per_character = 5
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=,fieldset="
[MSSQL]
mssql.allow_persistent = On
mssql.max_persistent = -1
mssql.max_links = -1
mssql.min_error_severity = 10
mssql.min_message_severity = 10
mssql.compatability_mode = Off
;mssql.connect_timeout = 5
;mssql.timeout = 60
; Valid range 0 - 2147483647.  Default = 4096.
;mssql.textlimit = 4096
;mssql.textsize = 4096
; Limits the number of records in each batch.  0 = all records in one batch.
;mssql.batchsize = 0
; Specify how datetime and datetim4 columns are returned
; On => Returns data converted to SQL server settings
; Off => Returns values as YYYY-MM-DD hh:mm:ss
;mssql.datetimeconvert = On
mssql.secure_connection = Off
;mssql.max_procs = -1
;mssql.charset = "ISO-8859-1"
[Assertion]
;assert.active = On
;assert.warning = On
;assert.bail = Off
;assert.callback = 0
; Eval the expression with current error_reporting().  Set to true if you want
; error_reporting(0) around the eval().
;assert.quiet_eval = 0
[COM]
;com.typelib_file =
;com.allow_dcom = true
;com.autoregister_typelib = true
;com.autoregister_casesensitive = false
;com.autoregister_verbose = true
;com.code_page=
[mbstring]
;mbstring.language = Japanese
;mbstring.internal_encoding = EUC-JP
;mbstring.http_input = auto
;mbstring.http_output = SJIS
;mbstring.encoding_translation = Off
;mbstring.detect_order = auto
;mbstring.substitute_character = none;
; 0: No overload
; 1: Overload mail() function
; 2: Overload str*() functions
; 4: Overload ereg*() functions
; 7: Overload everything functions
;mbstring.func_overload = 0
;mbstring.strict_detection = Off
; Default: mbstring.http_output_conv_mimetype=^(text/|application/xhtml\+xml)
;mbstring.http_output_conv_mimetype=
;mbstring.script_encoding=
[gd]
gd.jpeg_ignore_warning = 1
[exif]
;exif.encode_unicode = ISO-8859-15
;exif.decode_unicode_motorola = UCS-2BE
;exif.decode_unicode_intel    = UCS-2LE
;exif.encode_jis =
;exif.decode_jis_motorola = JIS
;exif.decode_jis_intel    = JIS
[Tidy]
;tidy.default_config = /usr/local/lib/php/default.tcfg
tidy.clean_output = Off
[soap]
soap.wsdl_cache_enabled=1
soap.wsdl_cache_dir="%sprogdir%/userdata/temp/"
soap.wsdl_cache_ttl=86400
soap.wsdl_cache_limit = 5
[sysvshm]
;sysvshm.init_mem = 10000
[ldap]
ldap.max_links = -1
[mcrypt]
;mcrypt.algorithms_dir=
;mcrypt.modes_dir=
[dba]
;dba.default_handler=
[Ioncube Loader]
zend_extension="%sprogdir%/modules/php/%phpdriver%/ext/php_ioncube.dll"
[Xdebug]
;zend_extension="%sprogdir%/modules/php/%phpdriver%/ext/php_xdebug.dll"
;xdebug.default_enable = 1
xdebug.auto_trace = 0
xdebug.collect_includes = 1
;xdebug.collect_params = 4
;xdebug.collect_return = 1
;xdebug.collect_assignments = 1
;xdebug.collect_vars = 1
xdebug.dump.REQUEST = *
xdebug.dump.SESSION = *
xdebug.dump.SERVER = REMOTE_ADDR,REQUEST_METHOD
;xdebug.dump.COOKIE =
;xdebug.dump.FILES =
;xdebug.dump.GET =
;xdebug.dump.POST =
xdebug.dump_globals = 1
xdebug.dump_once = 1
xdebug.dump_undefined = 1
xdebug.extended_info = 1
;xdebug.file_link_format = ""
;xdebug.idekey = ""
xdebug.max_nesting_level = 256
xdebug.overload_var_dump = 1
;xdebug.profiler_append = 1
xdebug.profiler_enable = 0
;xdebug.remote_autostart = 0
;xdebug.remote_enable = 1
;xdebug.remote_handler = "dbgp"
;xdebug.remote_host = "localhost"
;xdebug.remote_log = "none"
;xdebug.remote_mode = "req"
;xdebug.remote_port = 9000
;xdebug.scream = 1
;xdebug.show_local_vars = 1
;xdebug.show_mem_delta = 1
;xdebug.trace_format = 1
;xdebug.trace_options = 1
;xdebug.var_display_max_data = 1024
;xdebug.remote_cookie_expire_time = 3600
Re: PHP.INI - max_input_vars ?
Максим » 07 фев 2016, 23:52
Что мешает вписать, раз нет? Не понятно.
pro_vitaly
07 фев 2016, 23:28
pro_vitaly » 08 фев 2016, 00:05
Спасибо, помогло =)
