2016-01-21 14:34:01 2172 [Note] Plugin 'FEDERATED' is disabled. 2016-01-21 14:34:01 2172 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-01-21 14:34:01 2172 [Note] InnoDB: The InnoDB memory heap is disabled 2016-01-21 14:34:01 2172 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-01-21 14:34:01 2172 [Note] InnoDB: Memory barrier is not used 2016-01-21 14:34:01 2172 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-01-21 14:34:01 2172 [Note] InnoDB: Not using CPU crc32 instructions 2016-01-21 14:34:01 2172 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-01-21 14:34:01 2172 [Note] InnoDB: Completed initialization of buffer pool 2016-01-21 14:34:01 2172 [Note] InnoDB: Highest supported file format is Barracuda. 2016-01-21 14:34:01 2172 [Note] InnoDB: The log sequence numbers 36388115 and 36388115 in ibdata files do not match the log sequence number 36418748 in the ib_logfiles! 2016-01-21 14:34:01 2172 [Note] InnoDB: Database was not shutdown normally! 2016-01-21 14:34:01 2172 [Note] InnoDB: Starting crash recovery. 2016-01-21 14:34:01 2172 [Note] InnoDB: Reading tablespace information from the .ibd files... 2016-01-21 14:34:05 2172 [Note] InnoDB: Restoring possible half-written data pages 2016-01-21 14:34:05 2172 [Note] InnoDB: from the doublewrite buffer... InnoDB: Last MySQL binlog file position 0 26476, file name mysql-bin.000113 2016-01-21 14:34:09 2172 [Note] InnoDB: 128 rollback segment(s) are active. 2016-01-21 14:34:09 2172 [Note] InnoDB: Waiting for purge to start 2016-01-21 14:34:09 2172 [Note] InnoDB: 5.6.22 started; log sequence number 36418748 2016-01-21 14:34:09 2172 [Note] Recovering after a crash using mysql-bin 2016-01-21 14:34:09 2172 [Note] Starting crash recovery... 2016-01-21 14:34:09 2172 [Note] Crash recovery finished. 2016-01-21 14:34:10 2172 [Note] Server hostname (bind-address): '192.168.1.77'; port: 3306 2016-01-21 14:34:10 2172 [Note] - '192.168.1.77' resolves to '192.168.1.77'; 2016-01-21 14:34:10 2172 [Note] Server socket created on IP: '192.168.1.77'. 2016-01-21 14:34:11 2172 [Note] Event Scheduler: Loaded 0 events 2016-01-21 14:34:11 2172 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: ready for connections. Version: '5.6.22-log' socket: '' port: 3306 MySQL Community Server (GPL) 2016-01-21 14:56:10 2172 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Normal shutdown 2016-01-21 14:56:10 2172 [Note] Giving 0 client threads a chance to die gracefully 2016-01-21 14:56:10 2172 [Note] Event Scheduler: Purging the queue. 0 events 2016-01-21 14:56:10 2172 [Note] Shutting down slave threads 2016-01-21 14:56:10 2172 [Note] Forcefully disconnecting 0 remaining clients 2016-01-21 14:56:10 2172 [Note] Binlog end 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'partition' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_FIELDS' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_INDEXES' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_SYS_TABLES' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_FT_CONFIG' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_FT_DELETED' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_METRICS' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_CMPMEM' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_CMP_RESET' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_CMP' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_LOCK_WAITS' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_LOCKS' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'INNODB_TRX' 2016-01-21 14:56:11 2172 [Note] Shutting down plugin 'InnoDB' 2016-01-21 14:56:11 2172 [Note] InnoDB: FTS optimize thread exiting. 2016-01-21 14:56:11 2172 [Note] InnoDB: Starting shutdown... 2016-01-21 14:56:12 2172 [Note] InnoDB: Shutdown completed; log sequence number 36418870 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'BLACKHOLE' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'ARCHIVE' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'MRG_MYISAM' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'MyISAM' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'MEMORY' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'CSV' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'sha256_password' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'mysql_old_password' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'mysql_native_password' 2016-01-21 14:56:12 2172 [Note] Shutting down plugin 'binlog' 2016-01-21 14:56:12 2172 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete 2016-01-21 14:56:13 248 [Note] Plugin 'FEDERATED' is disabled. 2016-01-21 14:56:13 248 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-01-21 14:56:13 248 [Note] InnoDB: The InnoDB memory heap is disabled 2016-01-21 14:56:13 248 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-01-21 14:56:13 248 [Note] InnoDB: Memory barrier is not used 2016-01-21 14:56:13 248 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-01-21 14:56:13 248 [Note] InnoDB: Not using CPU crc32 instructions 2016-01-21 14:56:13 248 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-01-21 14:56:13 248 [Note] InnoDB: Completed initialization of buffer pool 2016-01-21 14:56:14 248 [Note] InnoDB: Highest supported file format is Barracuda. 2016-01-21 14:56:15 248 [Note] InnoDB: 128 rollback segment(s) are active. 2016-01-21 14:56:15 248 [Note] InnoDB: Waiting for purge to start 2016-01-21 14:56:15 248 [Note] InnoDB: 5.6.22 started; log sequence number 36418870 2016-01-21 14:56:15 248 [Note] Server hostname (bind-address): '192.168.1.77'; port: 3306 2016-01-21 14:56:15 248 [Note] - '192.168.1.77' resolves to '192.168.1.77'; 2016-01-21 14:56:15 248 [Note] Server socket created on IP: '192.168.1.77'. 2016-01-21 14:56:15 248 [Note] Event Scheduler: Loaded 0 events 2016-01-21 14:56:15 248 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: ready for connections. Version: '5.6.22-log' socket: '' port: 3306 MySQL Community Server (GPL) 2016-01-21 15:10:16 248 [ERROR] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Table '.\amxbanstris\amx_serverinfo' is marked as crashed and should be repaired 2016-01-21 15:10:16 248 [Warning] Checking table: '.\amxbanstris\amx_serverinfo' 2016-01-22 22:57:50 248 [ERROR] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Table '.\amxbanstris\amx_webadmins' is marked as crashed and should be repaired 2016-01-22 22:57:50 248 [Warning] Checking table: '.\amxbanstris\amx_webadmins' 2016-01-23 00:03:25 248 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Normal shutdown 2016-01-23 00:03:25 248 [Note] Giving 0 client threads a chance to die gracefully 2016-01-23 00:03:25 248 [Note] Event Scheduler: Purging the queue. 0 events 2016-01-23 00:03:25 248 [Note] Shutting down slave threads 2016-01-23 00:03:25 248 [Note] Forcefully disconnecting 0 remaining clients 2016-01-23 00:03:25 248 [Note] Binlog end 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'partition' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_FIELDS' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_INDEXES' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_SYS_TABLES' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_FT_CONFIG' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_FT_DELETED' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_METRICS' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_CMPMEM' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_CMP_RESET' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_CMP' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_LOCK_WAITS' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_LOCKS' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'INNODB_TRX' 2016-01-23 00:03:25 248 [Note] Shutting down plugin 'InnoDB' 2016-01-23 00:03:25 248 [Note] InnoDB: FTS optimize thread exiting. 2016-01-23 00:03:25 248 [Note] InnoDB: Starting shutdown... 2016-01-23 00:03:27 248 [Note] InnoDB: Shutdown completed; log sequence number 36452492 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'BLACKHOLE' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'ARCHIVE' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'MRG_MYISAM' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'MyISAM' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'MEMORY' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'CSV' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'sha256_password' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'mysql_old_password' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'mysql_native_password' 2016-01-23 00:03:27 248 [Note] Shutting down plugin 'binlog' 2016-01-23 00:03:27 248 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete 2016-01-23 00:03:32 3864 [Note] Plugin 'FEDERATED' is disabled. 2016-01-23 00:03:32 3864 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-01-23 00:03:32 3864 [Note] InnoDB: The InnoDB memory heap is disabled 2016-01-23 00:03:32 3864 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-01-23 00:03:32 3864 [Note] InnoDB: Memory barrier is not used 2016-01-23 00:03:32 3864 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-01-23 00:03:32 3864 [Note] InnoDB: Not using CPU crc32 instructions 2016-01-23 00:03:32 3864 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-01-23 00:03:32 3864 [Note] InnoDB: Completed initialization of buffer pool 2016-01-23 00:03:32 3864 [Note] InnoDB: Highest supported file format is Barracuda. 2016-01-23 00:03:35 3864 [Note] InnoDB: 128 rollback segment(s) are active. 2016-01-23 00:03:35 3864 [Note] InnoDB: Waiting for purge to start 2016-01-23 00:03:35 3864 [Note] InnoDB: 5.6.22 started; log sequence number 36452492 2016-01-23 00:03:35 3864 [Note] Server hostname (bind-address): '192.168.1.77'; port: 3306 2016-01-23 00:03:35 3864 [Note] - '192.168.1.77' resolves to '192.168.1.77'; 2016-01-23 00:03:35 3864 [Note] Server socket created on IP: '192.168.1.77'. 2016-01-23 00:03:36 3864 [Note] Event Scheduler: Loaded 0 events 2016-01-23 00:03:36 3864 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: ready for connections. Version: '5.6.22-log' socket: '' port: 3306 MySQL Community Server (GPL) 2016-01-23 03:48:32 3864 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Normal shutdown 2016-01-23 03:48:33 3864 [Note] Giving 0 client threads a chance to die gracefully 2016-01-23 03:48:33 3864 [Note] Event Scheduler: Purging the queue. 0 events 2016-01-23 03:48:33 3864 [Note] Shutting down slave threads 2016-01-23 03:48:33 3864 [Note] Forcefully disconnecting 0 remaining clients 2016-01-23 03:48:33 3864 [Note] Binlog end 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'partition' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_FIELDS' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_INDEXES' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_SYS_TABLES' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_FT_CONFIG' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_FT_DELETED' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_METRICS' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_CMPMEM' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_CMP_RESET' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_CMP' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_LOCK_WAITS' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_LOCKS' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'INNODB_TRX' 2016-01-23 03:48:33 3864 [Note] Shutting down plugin 'InnoDB' 2016-01-23 03:48:33 3864 [Note] InnoDB: FTS optimize thread exiting. 2016-01-23 03:48:33 3864 [Note] InnoDB: Starting shutdown... 2016-01-23 03:48:34 3864 [Note] InnoDB: Shutdown completed; log sequence number 36456589 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'BLACKHOLE' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'ARCHIVE' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'MRG_MYISAM' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'MyISAM' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'MEMORY' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'CSV' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'sha256_password' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'mysql_old_password' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'mysql_native_password' 2016-01-23 03:48:34 3864 [Note] Shutting down plugin 'binlog' 2016-01-23 03:48:34 3864 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete 2016-01-23 03:51:03 2760 [Note] Plugin 'FEDERATED' is disabled. 2016-01-23 03:51:04 2760 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-01-23 03:51:04 2760 [Note] InnoDB: The InnoDB memory heap is disabled 2016-01-23 03:51:04 2760 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-01-23 03:51:04 2760 [Note] InnoDB: Memory barrier is not used 2016-01-23 03:51:04 2760 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-01-23 03:51:04 2760 [Note] InnoDB: Not using CPU crc32 instructions 2016-01-23 03:51:04 2760 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-01-23 03:51:05 2760 [Note] InnoDB: Completed initialization of buffer pool 2016-01-23 03:51:05 2760 [Note] InnoDB: Highest supported file format is Barracuda. 2016-01-23 03:51:16 2760 [Note] InnoDB: 128 rollback segment(s) are active. 2016-01-23 03:51:16 2760 [Note] InnoDB: Waiting for purge to start 2016-01-23 03:51:16 2760 [Note] InnoDB: 5.6.22 started; log sequence number 36456589 2016-01-23 03:51:18 2760 [Note] Server hostname (bind-address): '192.168.1.77'; port: 3306 2016-01-23 03:51:18 2760 [Note] - '192.168.1.77' resolves to '192.168.1.77'; 2016-01-23 03:51:18 2760 [Note] Server socket created on IP: '192.168.1.77'. 2016-01-23 03:51:20 2760 [Note] Event Scheduler: Loaded 0 events 2016-01-23 03:51:20 2760 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: ready for connections. Version: '5.6.22-log' socket: '' port: 3306 MySQL Community Server (GPL) 2016-01-23 03:56:57 2760 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Normal shutdown 2016-01-23 03:56:57 2760 [Note] Giving 0 client threads a chance to die gracefully 2016-01-23 03:56:57 2760 [Note] Event Scheduler: Purging the queue. 0 events 2016-01-23 03:56:57 2760 [Note] Shutting down slave threads 2016-01-23 03:56:57 2760 [Note] Forcefully disconnecting 0 remaining clients 2016-01-23 03:56:57 2760 [Note] Binlog end 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'partition' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_FIELDS' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_INDEXES' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_SYS_TABLES' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_FT_CONFIG' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_FT_DELETED' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_METRICS' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_CMPMEM' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_CMP_RESET' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_CMP' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_LOCK_WAITS' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_LOCKS' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'INNODB_TRX' 2016-01-23 03:56:57 2760 [Note] Shutting down plugin 'InnoDB' 2016-01-23 03:56:57 2760 [Note] InnoDB: FTS optimize thread exiting. 2016-01-23 03:56:57 2760 [Note] InnoDB: Starting shutdown... 2016-01-23 03:56:58 2760 [Note] InnoDB: Shutdown completed; log sequence number 36456599 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'BLACKHOLE' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'ARCHIVE' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'MRG_MYISAM' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'MyISAM' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'MEMORY' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'CSV' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'sha256_password' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'mysql_old_password' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'mysql_native_password' 2016-01-23 03:56:58 2760 [Note] Shutting down plugin 'binlog' 2016-01-23 03:56:58 2760 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete 2016-01-23 03:58:58 2108 [Note] Plugin 'FEDERATED' is disabled. 2016-01-23 03:58:58 2108 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-01-23 03:58:58 2108 [Note] InnoDB: The InnoDB memory heap is disabled 2016-01-23 03:58:58 2108 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-01-23 03:58:58 2108 [Note] InnoDB: Memory barrier is not used 2016-01-23 03:58:58 2108 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-01-23 03:58:58 2108 [Note] InnoDB: Not using CPU crc32 instructions 2016-01-23 03:58:59 2108 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-01-23 03:58:59 2108 [Note] InnoDB: Completed initialization of buffer pool 2016-01-23 03:58:59 2108 [Note] InnoDB: Highest supported file format is Barracuda. 2016-01-23 03:59:02 2108 [Note] InnoDB: 128 rollback segment(s) are active. 2016-01-23 03:59:02 2108 [Note] InnoDB: Waiting for purge to start 2016-01-23 03:59:02 2108 [Note] InnoDB: 5.6.22 started; log sequence number 36456599 2016-01-23 03:59:02 2108 [Note] Server hostname (bind-address): '192.168.1.77'; port: 3306 2016-01-23 03:59:02 2108 [Note] - '192.168.1.77' resolves to '192.168.1.77'; 2016-01-23 03:59:02 2108 [Note] Server socket created on IP: '192.168.1.77'. 2016-01-23 03:59:06 2108 [Note] Event Scheduler: Loaded 0 events 2016-01-23 03:59:06 2108 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: ready for connections. Version: '5.6.22-log' socket: '' port: 3306 MySQL Community Server (GPL) 2016-01-30 16:38:21 2108 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Normal shutdown 2016-01-30 16:38:21 2108 [Note] Giving 0 client threads a chance to die gracefully 2016-01-30 16:38:21 2108 [Note] Event Scheduler: Purging the queue. 0 events 2016-01-30 16:38:21 2108 [Note] Shutting down slave threads 2016-01-30 16:38:22 2108 [Note] Forcefully disconnecting 0 remaining clients 2016-01-30 16:38:22 2108 [Note] Binlog end 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'partition' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_FIELDS' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_INDEXES' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_SYS_TABLES' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_FT_CONFIG' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_FT_DELETED' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_METRICS' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_CMPMEM' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_CMP_RESET' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_CMP' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_LOCK_WAITS' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_LOCKS' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'INNODB_TRX' 2016-01-30 16:38:27 2108 [Note] Shutting down plugin 'InnoDB' 2016-01-30 16:38:27 2108 [Note] InnoDB: FTS optimize thread exiting. 2016-01-30 16:38:27 2108 [Note] InnoDB: Starting shutdown... 2016-01-30 16:38:33 2108 [Note] InnoDB: Shutdown completed; log sequence number 36607075 2016-01-30 16:38:33 2108 [Note] Shutting down plugin 'BLACKHOLE' 2016-01-30 16:38:33 2108 [Note] Shutting down plugin 'ARCHIVE' 2016-01-30 16:38:33 2108 [Note] Shutting down plugin 'MRG_MYISAM' 2016-01-30 16:38:34 2108 [Note] Shutting down plugin 'MyISAM' 2016-01-30 16:38:34 2108 [Note] Shutting down plugin 'MEMORY' 2016-01-30 16:38:34 2108 [Note] Shutting down plugin 'CSV' 2016-01-30 16:38:34 2108 [Note] Shutting down plugin 'sha256_password' 2016-01-30 16:38:34 2108 [Note] Shutting down plugin 'mysql_old_password' 2016-01-30 16:38:34 2108 [Note] Shutting down plugin 'mysql_native_password' 2016-01-30 16:38:34 2108 [Note] Shutting down plugin 'binlog' 2016-01-30 16:38:34 2108 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete 2016-01-30 16:53:55 2972 [Note] Plugin 'FEDERATED' is disabled. 2016-01-30 16:53:55 2972 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-01-30 16:53:55 2972 [Note] InnoDB: The InnoDB memory heap is disabled 2016-01-30 16:53:55 2972 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-01-30 16:53:55 2972 [Note] InnoDB: Memory barrier is not used 2016-01-30 16:53:55 2972 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-01-30 16:53:56 2972 [Note] InnoDB: Not using CPU crc32 instructions 2016-01-30 16:53:56 2972 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-01-30 16:53:56 2972 [Note] InnoDB: Completed initialization of buffer pool 2016-01-30 16:53:56 2972 [Note] InnoDB: Highest supported file format is Barracuda. 2016-01-30 16:53:58 2972 [Note] InnoDB: 128 rollback segment(s) are active. 2016-01-30 16:53:59 2972 [Note] InnoDB: Waiting for purge to start 2016-01-30 16:53:59 2972 [Note] InnoDB: 5.6.22 started; log sequence number 36607075 2016-01-30 16:53:59 2972 [Note] Server hostname (bind-address): '192.168.1.77'; port: 3306 2016-01-30 16:53:59 2972 [Note] - '192.168.1.77' resolves to '192.168.1.77'; 2016-01-30 16:53:59 2972 [Note] Server socket created on IP: '192.168.1.77'. 2016-01-30 16:54:02 2972 [Note] Event Scheduler: Loaded 0 events 2016-01-30 16:54:02 2972 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: ready for connections. Version: '5.6.22-log' socket: '' port: 3306 MySQL Community Server (GPL) 2016-01-30 17:20:24 2972 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Normal shutdown 2016-01-30 17:20:24 2972 [Note] Giving 0 client threads a chance to die gracefully 2016-01-30 17:20:24 2972 [Note] Event Scheduler: Purging the queue. 0 events 2016-01-30 17:20:24 2972 [Note] Shutting down slave threads 2016-01-30 17:20:24 2972 [Note] Forcefully disconnecting 0 remaining clients 2016-01-30 17:20:24 2972 [Note] Binlog end 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'partition' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_FIELDS' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_INDEXES' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_SYS_TABLES' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_FT_CONFIG' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_FT_DELETED' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_METRICS' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_CMPMEM' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_CMP_RESET' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_CMP' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_LOCK_WAITS' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_LOCKS' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'INNODB_TRX' 2016-01-30 17:20:24 2972 [Note] Shutting down plugin 'InnoDB' 2016-01-30 17:20:24 2972 [Note] InnoDB: FTS optimize thread exiting. 2016-01-30 17:20:24 2972 [Note] InnoDB: Starting shutdown... 2016-01-30 17:20:25 2972 [Note] InnoDB: Shutdown completed; log sequence number 36612040 2016-01-30 17:20:25 2972 [Note] Shutting down plugin 'BLACKHOLE' 2016-01-30 17:20:25 2972 [Note] Shutting down plugin 'ARCHIVE' 2016-01-30 17:20:25 2972 [Note] Shutting down plugin 'MRG_MYISAM' 2016-01-30 17:20:25 2972 [Note] Shutting down plugin 'MyISAM' 2016-01-30 17:20:25 2972 [Note] Shutting down plugin 'MEMORY' 2016-01-30 17:20:25 2972 [Note] Shutting down plugin 'CSV' 2016-01-30 17:20:25 2972 [Note] Shutting down plugin 'sha256_password' 2016-01-30 17:20:26 2972 [Note] Shutting down plugin 'mysql_old_password' 2016-01-30 17:20:26 2972 [Note] Shutting down plugin 'mysql_native_password' 2016-01-30 17:20:26 2972 [Note] Shutting down plugin 'binlog' 2016-01-30 17:20:26 2972 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete 2016-01-30 18:28:22 1700 [Note] Plugin 'FEDERATED' is disabled. 2016-01-30 18:28:23 1700 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-01-30 18:28:23 1700 [Note] InnoDB: The InnoDB memory heap is disabled 2016-01-30 18:28:23 1700 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-01-30 18:28:23 1700 [Note] InnoDB: Memory barrier is not used 2016-01-30 18:28:23 1700 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-01-30 18:28:23 1700 [Note] InnoDB: Not using CPU crc32 instructions 2016-01-30 18:28:23 1700 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-01-30 18:28:23 1700 [Note] InnoDB: Completed initialization of buffer pool 2016-01-30 18:28:23 1700 [Note] InnoDB: Highest supported file format is Barracuda. 2016-01-30 18:28:26 1700 [Note] InnoDB: 128 rollback segment(s) are active. 2016-01-30 18:28:26 1700 [Note] InnoDB: Waiting for purge to start 2016-01-30 18:28:26 1700 [Note] InnoDB: 5.6.22 started; log sequence number 36612040 2016-01-30 18:28:27 1700 [Note] Server hostname (bind-address): '192.168.1.77'; port: 3306 2016-01-30 18:28:27 1700 [Note] - '192.168.1.77' resolves to '192.168.1.77'; 2016-01-30 18:28:27 1700 [Note] Server socket created on IP: '192.168.1.77'. 2016-01-30 18:28:29 1700 [Note] Event Scheduler: Loaded 0 events 2016-01-30 18:28:29 1700 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: ready for connections. Version: '5.6.22-log' socket: '' port: 3306 MySQL Community Server (GPL) 2016-01-30 19:42:19 2140 [Note] Plugin 'FEDERATED' is disabled. 2016-01-30 19:42:20 2140 [Note] InnoDB: Using atomics to ref count buffer pool pages 2016-01-30 19:42:20 2140 [Note] InnoDB: The InnoDB memory heap is disabled 2016-01-30 19:42:20 2140 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2016-01-30 19:42:20 2140 [Note] InnoDB: Memory barrier is not used 2016-01-30 19:42:20 2140 [Note] InnoDB: Compressed tables use zlib 1.2.3 2016-01-30 19:42:20 2140 [Note] InnoDB: Not using CPU crc32 instructions 2016-01-30 19:42:20 2140 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2016-01-30 19:42:20 2140 [Note] InnoDB: Completed initialization of buffer pool 2016-01-30 19:42:21 2140 [Note] InnoDB: Highest supported file format is Barracuda. 2016-01-30 19:42:21 2140 [Note] InnoDB: The log sequence numbers 36612040 and 36612040 in ibdata files do not match the log sequence number 36612050 in the ib_logfiles! 2016-01-30 19:42:21 2140 [Note] InnoDB: Database was not shutdown normally! 2016-01-30 19:42:21 2140 [Note] InnoDB: Starting crash recovery. 2016-01-30 19:42:21 2140 [Note] InnoDB: Reading tablespace information from the .ibd files... 2016-01-30 19:42:24 2140 [Note] InnoDB: Restoring possible half-written data pages 2016-01-30 19:42:24 2140 [Note] InnoDB: from the doublewrite buffer... InnoDB: Last MySQL binlog file position 0 1765, file name mysql-bin.000119 2016-01-30 19:42:28 2140 [Note] InnoDB: 128 rollback segment(s) are active. 2016-01-30 19:42:28 2140 [Note] InnoDB: Waiting for purge to start 2016-01-30 19:42:28 2140 [Note] InnoDB: 5.6.22 started; log sequence number 36612050 d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Error on delete of '.\mysql-bin.index' (Errcode: 22 - Invalid argument) d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Error on rename of '.\mysql-bin.index_crash_safe' to '.\mysql-bin.index' (Errcode: 22 - Invalid argument) 2016-01-30 19:42:28 2140 [ERROR] MYSQL_BIN_LOG::move_crash_safe_index_file_to_index_file failed to move crash_safe_index_file to index file. 2016-01-30 19:42:28 2140 [ERROR] MYSQL_BIN_LOG::add_log_to_index failed to move crash safe index file to index file. 16:42:29 UTC - mysqld got exception 0xc0000005 ; This could be because you hit a bug. It is also possible that this binary or one of the libraries it was linked against is corrupt, improperly built, or misconfigured. This error can also be caused by malfunctioning hardware. We will try our best to scrape up some info that will hopefully help diagnose the problem, but since we have already crashed, something is definitely wrong and this may fail. key_buffer_size=26214400 read_buffer_size=2097152 max_used_connections=0 max_threads=30 thread_count=0 connection_count=0 It is possible that mysqld could use up to key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 118043 K bytes of memory Hope that's ok; if not, decrease some variables in the equation. Thread pointer: 0x0 Attempting backtrace. You can use the following information to find out where mysqld died. If you see no messages after this, something went terribly wrong... 66c170 mysqld.exe!my_b_gets() 630c7e mysqld.exe!?opt_sum_query@@YAHPAVTHD@@PAUTABLE_LIST@@AAV?$List@VItem@@@@PAVItem@@@Z() 63149b mysqld.exe!?opt_sum_query@@YAHPAVTHD@@PAUTABLE_LIST@@AAV?$List@VItem@@@@PAVItem@@@Z() 635917 mysqld.exe!?opt_sum_query@@YAHPAVTHD@@PAUTABLE_LIST@@AAV?$List@VItem@@@@PAVItem@@@Z() 411c0d mysqld.exe!?init_common_variables@@YAHXZ() 412548 mysqld.exe!?win_main@@YAHHPAPAD@Z() 412ab7 mysqld.exe!?mysql_service@@YAHPAX@Z() 8a340a mysqld.exe!my_mb_ctype_mb() 7c817077 kernel32.dll!RegisterWaitForInputIdle() The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains information that should help you find out what is causing the crash. d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Error on rename of '.\mysql-bin.index_crash_safe' to '.\mysql-bin.index' (Errcode: 22 - Invalid argument) 2016-01-30 19:43:00 3268 [ERROR] MYSQL_BIN_LOG::open_index_file failed to move crash_safe_index_file to index file. 2016-01-30 19:43:00 3268 [ERROR] Aborting 2016-01-30 19:43:00 3268 [Note] Binlog end 2016-01-30 19:43:00 3268 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Error on rename of '.\mysql-bin.index_crash_safe' to '.\mysql-bin.index' (Errcode: 22 - Invalid argument) 2016-01-31 00:15:45 616 [ERROR] MYSQL_BIN_LOG::open_index_file failed to move crash_safe_index_file to index file. 2016-01-31 00:15:45 616 [ERROR] Aborting 2016-01-31 00:15:45 616 [Note] Binlog end 2016-01-31 00:15:45 616 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Error on rename of '.\mysql-bin.index_crash_safe' to '.\mysql-bin.index' (Errcode: 22 - Invalid argument) 2016-01-31 19:13:18 2344 [ERROR] MYSQL_BIN_LOG::open_index_file failed to move crash_safe_index_file to index file. 2016-01-31 19:13:18 2344 [ERROR] Aborting 2016-01-31 19:13:18 2344 [Note] Binlog end 2016-01-31 19:13:18 2344 [Note] d:\openserver\modules\database\MySQL-5.6\bin\mysqld.exe: Shutdown complete
- Текущее время: 19 ноя 2026, 06:58
