Не окрываются домены
kvsemenoff
04 июл 2015, 14:58
kvsemenoff » 06 окт 2015, 10:10
Openserver запускается нормально, но браузер не открывает сайты.
Порт 80 не занят, hosts обновляется нормально.
Уже второй месяц не могу решить проблему. Помогите, пожалуйста.Что я делаю нет так?
[upd=1444129133][/upd]
Это код, который находится во вкладке "Apache отладка"
[Tue Oct 06 13:43:43 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Tue Oct 06 13:43:43 2015] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Tue Oct 06 13:43:43 2015] [notice] Apache/2.2.29 (Win32) mod_ssl/2.2.29 OpenSSL/0.9.8zc configured -- resuming normal operations
[Tue Oct 06 13:43:43 2015] [notice] Server built: Sep 10 2014 11:58:36
[Tue Oct 06 13:43:43 2015] [notice] Parent: Created child process 6660
[Tue Oct 06 13:43:44 2015] [notice] Disabled use of AcceptEx() WinSock2 API
[Tue Oct 06 13:43:44 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Tue Oct 06 13:43:44 2015] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Tue Oct 06 13:43:44 2015] [notice] Child 6660: Child process is running
[Tue Oct 06 13:43:44 2015] [notice] Child 6660: Acquired the start mutex.
[Tue Oct 06 13:43:44 2015] [notice] Child 6660: Starting 32 worker threads.
[Tue Oct 06 13:43:44 2015] [notice] Child 6660: Listening on port 443.
[Tue Oct 06 13:43:44 2015] [notice] Child 6660: Listening on port 80.
А вот вкладка "MySQL отладка"
151006 13:43:43 [Note] Plugin 'FEDERATED' is disabled.
151006 13:43:43 InnoDB: The InnoDB memory heap is disabled
151006 13:43:43 InnoDB: Mutexes and rw_locks use Windows interlocked functions
151006 13:43:43 InnoDB: Compressed tables use zlib 1.2.3
151006 13:43:43 InnoDB: Initializing buffer pool, size = 20.0M
151006 13:43:43 InnoDB: Completed initialization of buffer pool
151006 13:43:43 InnoDB: highest supported file format is Barracuda.
151006 13:43:43  InnoDB: Waiting for the background threads to start
151006 13:43:44 InnoDB: 5.5.41 started; log sequence number 1595675
151006 13:43:44 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
151006 13:43:44 [Note]   - '127.0.0.1' resolves to '127.0.0.1';
151006 13:43:44 [Note] Server socket created on IP: '127.0.0.1'.
151006 13:43:44 [Note] Event Scheduler: Loaded 0 events
151006 13:43:44 [Note] c:\openserver\modules\database\MySQL-5.5\bin\mysqld.exe: ready for connections.
Version: '5.5.41-log'  socket: ''  port: 3306  MySQL Community Server (GPL)
[upd=1444129274][/upd]
Вкладка "Основной"
2015-10-06 13:43:42  --------------------------------------------
2015-10-06 13:43:42  Начало процедуры запуска сервера
2015-10-06 13:43:42  Обновление Hosts файла
2015-10-06 13:43:42  Обновление конфигурации MySQL-5.5
2015-10-06 13:43:42  Обновление конфигурации Sendmail
2015-10-06 13:43:42  Обновление конфигурации PHP-5.3
2015-10-06 13:43:42  Обновление конфигурации PHPMyAdmin
2015-10-06 13:43:42  Обновление конфигурации Apache-2.2
2015-10-06 13:43:42  Запуск MySQL-5.5
2015-10-06 13:43:42  Запуск Apache-2.2
2015-10-06 13:43:43  Проверка состояния сервера
2015-10-06 13:43:44  Cервер успешно запущен за 2,059 секунд!
vikroR
06 окт 2015, 23:08
vikroR » 06 окт 2015, 23:20
А пробовал открыть админера или phpMyAdmin? Они тоже не открываются?
Что открывается по адресу http://localhost/ ?
Кстати, а что значит сайты не открываются? Белое окно или "Веб-страница недоступна"?
kvsemenoff
04 июл 2015, 14:58
kvsemenoff » 07 окт 2015, 12:32
vikroR, phpmyadmin тоже не работает. Пишет, что веб-страница недоступна.
Я уже все что можно представить перепробовал, но ничего не помогает.
Уже перестаю верить, что существует работающий openserver.
vikroR
06 окт 2015, 23:08
vikroR » 07 окт 2015, 12:50
Попробуйте отключить скайп))
kvsemenoff
04 июл 2015, 14:58
kvsemenoff » 07 окт 2015, 12:56
скайп тоже отключал. не работает
kakaze
27 авг 2015, 18:03
kakaze » 07 окт 2015, 13:56
опен портативен, попробуйте чистую версию из коробки, по умолч для элементарного запуска хватит ток предварительной настройки вкладки Сервер в настройках.
kvsemenoff
04 июл 2015, 14:58
kvsemenoff » 09 окт 2015, 07:53
не работает :cry:
kakaze
27 авг 2015, 18:03
kakaze » 09 окт 2015, 13:53
покажите скрин вкладки Сервер. и в хост точно добавляются записи о локальных доменах? а то мб стоит вручную добавить (ну мало ли).
вообщем опен из коробки должен спокойно работать, я хз может ли чо внешнее этому препятствовать (хотя зная наших пользователей все может быть ;) ).
мануал гляньте мб вы чо не так делаете.
kvsemenoff
04 июл 2015, 14:58
kvsemenoff » 09 окт 2015, 18:28
в хост все записывается корректно.
akcuoma
13 дек 2015, 14:15
Re: Не окрываются домены
akcuoma » 13 дек 2015, 22:44
У меня тоже самое, все работало отлично, а потом я поставил adobe илюстратор, доделал ЛП и вырубил комп на ночь, утром уже не работал сервак. Вот что в HOSTS C:\Windows\System32\drivers\etc и как выше на скрине все тоже самое
# Start Open Server 581fd75ee1845da9fce3c419ef4d30f0_hosts
127.0.0.1 localhost
127.0.0.1 open-server.ru (это для теста, переустановил сервак)
# End Open Server 581fd75ee1845da9fce3c419ef4d30f0_hosts
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
