[Fri Oct 11 13:29:02 2013] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Fri Oct 11 13:29:02 2013] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Fri Oct 11 13:29:02 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Oct 11 13:29:03 2013] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Fri Oct 11 13:29:03 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Oct 11 13:29:09 2013] [notice] Apache/2.2.25 (Win32) mod_ssl/2.2.25 OpenSSL/0.9.8y configured -- resuming normal operations
[Fri Oct 11 13:29:09 2013] [notice] Server built: Jun 29 2013 16:08:05
[Fri Oct 11 13:29:09 2013] [notice] Parent: Created child process 2872
[Fri Oct 11 13:29:09 2013] [notice] Disabled use of AcceptEx() WinSock2 API
[Fri Oct 11 13:29:09 2013] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Fri Oct 11 13:29:09 2013] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Fri Oct 11 13:29:09 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Oct 11 13:29:12 2013] [notice] Child 2872: Child process is running
[Fri Oct 11 13:29:12 2013] [notice] Child 2872: Acquired the start mutex.
[Fri Oct 11 13:29:12 2013] [notice] Child 2872: Starting 32 worker threads.
[Fri Oct 11 13:29:12 2013] [notice] Child 2872: Listening on port 443.
[Fri Oct 11 13:29:12 2013] [notice] Child 2872: Listening on port 80.
[Fri Oct 11 15:15:30 2013] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/modules/system/html/default/favicon.ico, referer: http://torrentszona.com/
[Fri Oct 11 15:57:21 2013] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/modules/system/html/default/favicon.ico, referer: http://127.0.0.1/
[Fri Oct 11 15:58:20 2013] [error] [client 127.0.0.1] script 'C:/OpenServer/modules/system/html/default/index.php' not found or unable to stat
- Текущее время: 09 ноя 2026, 08:59
