настройки в ide:
http://clip2net.com/s/4V3dg7
настройки в openserver:
http://clip2net.com/s/4V3fBN
http://clip2net.com/s/4V3hho
php.ini
[Xdebug] zend_extension="%sprogdir%/modules/php/%phpdriver%/ext/php_xdebug.dll" xdebug.auto_trace = 1 ;xdebug.collect_includes = 1 ;xdebug.collect_params = 0 ;xdebug.collect_return = 0 ;xdebug.collect_vars = 0 xdebug.default_enable = 1 ;xdebug.dump.SERVER = REMOTE_ADDR,REQUEST_METHOD ;xdebug.dump.SERVER = REMOTE_ADDR,REQUEST_METHOD ;xdebug.dump.COOKIE = "" ;xdebug.dump.FILES = "" ;xdebug.dump.GET = "" ;xdebug.dump.POST = "" ;xdebug.dump.REQUEST = "" ;xdebug.dump.SERVER = "" ;xdebug.dump.SESSION = "" ;xdebug.dump_globals = 1 ;xdebug.dump_once = 1 ;xdebug.dump_undefined = 0 ;xdebug.extended_info = 1 ;xdebug.file_link_format = "" ;xdebug.idekey = "" ;xdebug.manual_url = "http://www.php.net" ;xdebug.max_nesting_level = 100 xdebug.overload_var_dump = 1 ;xdebug.profiler_append = 0 xdebug.profiler_enable = 1 xdebug.profiler_enable_trigger = 1 xdebug.profiler_output_dir="%sprogdir%/userdata/temp/xdebug/" xdebug.profiler_output_name = "cachegrind.out.%H%R" xdebug.remote_autostart = 0 xdebug.remote_enable = 1 xdebug.remote_handler = "dbgp" xdebug.remote_host = "localhost" xdebug.remote_log = "none" xdebug.remote_mode = "req" xdebug.remote_port = 9000 xdebug.show_exception_trace = 1 ;xdebug.show_local_vars = 0 ;xdebug.show_mem_delta = 0 ;xdebug.trace_format = 0 ;xdebug.trace_options = 0 xdebug.trace_output_dir = "%sprogdir%/userdata/temp/xdebug/" ;xdebug.trace_output_name = "trace.%H%R" ;xdebug.var_display_max_children = 128 ;xdebug.var_display_max_data = 512 ;xdebug.var_display_max_depth = 3
 я сделал как в указанной выше теме, запустил диск батником и все браузеры его видят...
