помогите решить пожалуйста
Fatal error: Uncaught Exception: Error: Variable 'sql_mode' can't be set to the value of 'MYSQL40'<br />Error No: 1231<br />SET @@session.sql_mode = 'MYSQL40' in D:\OpenServer\domains\budivelnyk\system\library\db\mysqli.php:40 Stack trace: #0 D:\OpenServer\domains\budivelnyk\system\library\db.php(45): DB\MySQLi->query('SET @@session.s...') #1 D:\OpenServer\domains\budivelnyk\install\model\install\install.php(35): DB->query('SET @@session.s...') #2 D:\OpenServer\domains\budivelnyk\system\engine\loader.php(248): ModelInstallInstall->database(Array) #3 D:\OpenServer\domains\budivelnyk\system\engine\proxy.php(47): Loader->{closure}(Array, Array) #4 D:\OpenServer\domains\budivelnyk\install\controller\install\step_3.php(11): Proxy->__call('database', Array) #5 D:\OpenServer\domains\budivelnyk\system\engine\action.php(79): ControllerInstallStep3->index() #6 D:\OpenServer\domains\budivelnyk\system\engine\router.php(67): Action->execute(Object(Registry)) #7 D:\OpenServer\domains\budivelnyk\system\engine\router.php(56): Router->exe in D:\OpenServer\domains\budivelnyk\system\library\db\mysqli.php on line 40
- Текущее время: 30 окт 2026, 15:24
