У меня вот такая проблема как на скринах кто поможет решить ?
Я первый раз устанавливаю это (Хочу создать и открыть интернет магазин)
Первая ошибка https://drive.google.com/file/d/1deEoxH ... sp=sharing
Вторая ошибка https://drive.google.com/file/d/1ul4Zy2 ... sp=sharing
Код первой ошибки
Unknown: The Twig_Autoloader class is deprecated since version 1.21 and will be removed in 2.0. Use Composer instead. in D:\OpenServer\domains\test1.md\system\library\template\Twig\Autoloader.php on line 12Unknown: Using Twig_Autoloader is deprecated since version 1.21. Use Composer instead. in D:\OpenServer\domains\test1.md\system\library\template\Twig\Autoloader.php on line 30Unknown: Using Twig_Autoloader is deprecated since version 1.21. Use Composer instead. in D:\OpenServer\domains\test1.md\system\library\template\Twig\Autoloader.php on line 30Unknown: Using Twig_Autoloader is deprecated since version 1.21. Use Composer instead. in D:\OpenServer\domains\test1.md\system\library\template\Twig\Autoloader.php on line 30Unknown: Using Twig_Autoloader is deprecated since version 1.21. Use Composer instead. in D:\OpenServer\domains\test1.md\system\library\template\Twig\Autoloader.php on line 30
Код второй ошибки
Warning: mysqli::__construct(): (HY000/1045): Access denied for user 'root'@'localhost' (using password: NO) in D:\OpenServer\domains\test1.md\system\library\db\mysqli.php on line 7
Fatal error: Uncaught Error: mysqli object is already closed in D:\OpenServer\domains\test1.md\system\library\db\mysqli.php:10 Stack trace: #0 D:\OpenServer\domains\test1.md\install\controller\install\step_3.php(275): DB\MySQLi->__construct() #1 D:\OpenServer\domains\test1.md\install\controller\install\step_3.php(8): ControllerInstallStep3->validate() #2 D:\OpenServer\domains\test1.md\system\engine\action.php(79): ControllerInstallStep3->index() #3 D:\OpenServer\domains\test1.md\system\engine\router.php(67): Action->execute() #4 D:\OpenServer\domains\test1.md\system\engine\router.php(56): Router->execute() #5 D:\OpenServer\domains\test1.md\system\framework.php(168): Router->dispatch() #6 D:\OpenServer\domains\test1.md\system\startup.php(104): require_once('D:\\OpenServer\\d...') #7 D:\OpenServer\domains\test1.md\install\index.php(40): start() #8 {main} thrown in D:\OpenServer\domains\test1.md\system\library\db\mysqli.php on line 10
- Текущее время: 04 ноя 2026, 16:35
