Парни срочно нужен ответ!
С дуру поставил новую версию поверх старой.
Сайты остались, старые файлы в базе остались.
В PHPMyAdmin баз нет.
Сайты писали сперва - Warning: session_start(): Failed to read session data: user (path: e:/openserver/ospanel/userdata/temp/) in E:\OpenServer\OSPanel\domains\Domkomexpr\libraries\joomla\session\handler\native.php on line 260
Error: Failed to start application: Failed to start the session
После того как поставил старую вверсию - Error: Failed to start application: Could not connect to MySQL server.
Сообщение консоли
> mysqld --console
mysqld: Could not create or access the registry key needed for the MySQL application
to log to the Windows EventLog. Run the application with sufficient
privileges once to create the key, add the key manually, or turn off
logging for that application.
2019-07-31T05:55:19.054166Z 0 [ERROR] Cannot open Windows EventLog; check privileges, or start server with --log_syslog=0
2019-07-31T05:55:19.054166Z 0 [Note] mysqld (mysqld 5.7.19) starting as process 17132 ...
2019-07-31T05:55:19.085082Z 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2019-07-31T05:55:19.086078Z 0 [Note] InnoDB: Uses event mutexes
2019-07-31T05:55:19.087079Z 0 [Note] InnoDB: _mm_lfence() and _mm_sfence() are used for memory barrier
2019-07-31T05:55:19.088074Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.3
2019-07-31T05:55:19.089070Z 0 [Note] InnoDB: Number of pools: 1
2019-07-31T05:55:19.090068Z 0 [Note] InnoDB: Not using CPU crc32 instructions
2019-07-31T05:55:19.098047Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2019-07-31T05:55:19.108020Z 0 [Note] InnoDB: Completed initialization of buffer pool
2019-07-31T05:55:19.156344Z 0 [ERROR] InnoDB: The innodb_system data file 'ibdata1' must be writable
2019-07-31T05:55:19.157340Z 0 [ERROR] InnoDB: The innodb_system data file 'ibdata1' must be writable
2019-07-31T05:55:19.157340Z 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2019-07-31T05:55:19.360640Z 0 [ERROR] Plugin 'InnoDB' init function returned error.
2019-07-31T05:55:19.361641Z 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2019-07-31T05:55:19.362656Z 0 [ERROR] Failed to initialize plugins.
2019-07-31T05:55:19.363636Z 0 [ERROR] Aborting
2019-07-31T05:55:19.364633Z 0 [Note] Binlog end
2019-07-31T05:55:19.366659Z 0 [Note] Shutting down plugin 'CSV'
2019-07-31T05:55:19.368653Z 0 [Note] mysqld: Shutdown complete
Очень много проектов накрылось, в том числе рабочих.
Скажите, можно ли восстановить? Заранее благодарен за ценные ответы.
Все выше предложенные вариант пробовал - результата ноль.
ЗЫ Попробывал поставить сайт с нуля, на этапе конфигурации базы данных выдает ошибку Не удалось подключиться к базе данных. Текст сообщения об ошибке: Could not connect to MySQL server.
- Текущее время: 27 апр 2024, 23:43
