логи апача:
[Wed Apr 12 13:21:51 2017] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Apr 12 13:21:51 2017] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Apr 12 13:21:51 2017] [notice] Apache/2.2.31 (Win32) mod_ssl/2.2.31 OpenSSL/1.0.1p configured -- resuming normal operations [Wed Apr 12 13:21:51 2017] [notice] Server built: Jul 16 2015 11:30:50 [Wed Apr 12 13:21:51 2017] [notice] Parent: Created child process 6848 [Wed Apr 12 13:21:51 2017] [notice] Disabled use of AcceptEx() WinSock2 API [Wed Apr 12 13:21:52 2017] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Apr 12 13:21:52 2017] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Wed Apr 12 13:21:52 2017] [notice] Child 6848: Child process is running [Wed Apr 12 13:21:52 2017] [notice] Child 6848: Acquired the start mutex. [Wed Apr 12 13:21:52 2017] [notice] Child 6848: Starting 32 worker threads. [Wed Apr 12 13:21:52 2017] [notice] Child 6848: Listening on port 443. [Wed Apr 12 13:21:52 2017] [notice] Child 6848: Listening on port 80. [Wed Apr 12 13:22:06 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/framework/ [Wed Apr 12 13:22:06 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/protected/ [Wed Apr 12 13:22:06 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/favicon.ico, referer: http://test685.ru/ [Wed Apr 12 13:22:35 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/framework/ [Wed Apr 12 13:22:35 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/protected/ [Wed Apr 12 13:22:36 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/framework/ [Wed Apr 12 13:22:36 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/protected/ [Wed Apr 12 13:22:36 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/framework/ [Wed Apr 12 13:22:36 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/protected/ [Wed Apr 12 13:22:37 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/framework/ [Wed Apr 12 13:22:37 2017] [error] [client 127.0.0.1] client denied by server configuration: C:/OpenServer/domains/test685.ru/protected/ [Wed Apr 12 13:22:37 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:38 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:39 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:39 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:40 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:40 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:40 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:41 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:41 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/ [Wed Apr 12 13:22:41 2017] [error] [client 127.0.0.1] File does not exist: C:/OpenServer/domains/test685.ru/russian-lenses, referer: http://test685.ru/Из-за чего такое, раньше все норм было?
