%phpdir% и AppServ , проблемы
vedmaka
13 фев 2012, 19:06
vedmaka » 13 фев 2012, 19:41
Стоял AppServ, поставил OpenServer, запустил "Первый запуск".
Конф - Apache + php5.3 + mysql
В процессе работы стали вылезать ошибки, из которых стало понятно, что %phpdir% , который используется в файлах конфига ведет на php от AppServ (C:\AppServ\php5) вместо C:\OpenServer\server\php\PHP-5.3.9, вот лог:
[Mon Feb 13 20:00:07 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Mon Feb 13 20:00:09 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Mon Feb 13 20:00:13 2012] [notice] Apache/2.2.21 (Win32) mod_ssl/2.2.21 OpenSSL/0.9.8r PHP/5.3.9 configured -- resuming normal operations
[Mon Feb 13 20:00:13 2012] [notice] Server built: Sep 16 2011 12:06:30
[Mon Feb 13 20:00:13 2012] [notice] Parent: Created child process 26748
[Mon Feb 13 20:00:17 2012] [notice] Disabled use of AcceptEx() WinSock2 API
[Mon Feb 13 20:00:18 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Mon Feb 13 20:00:19 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Mon Feb 13 20:00:20 2012] [notice] Child 26748: Child process is running
[Mon Feb 13 20:00:20 2012] [notice] Child 26748: Acquired the start mutex.
[Mon Feb 13 20:00:20 2012] [notice] Child 26748: Starting 10 worker threads.
[Mon Feb 13 20:00:20 2012] [notice] Child 26748: Listening on port 443.
[Mon Feb 13 20:00:20 2012] [notice] Child 26748: Listening on port 80.
[Mon Feb 13 20:00:35 2012] [error] [client 127.0.0.1] (20024)The given path is misformatted or contained invalid characters: Cannot map POST /index.php/%D0%A1%D0%BB%D1%83%D0%B6%D0%B5%D0%B1%D0%BD%D0%B0%D1%8F:UpdateProfile HTTP/1.1 to file, referer: http://mediawiki.local/index.php/%D0%A1%D0%BB%D1%83%D0%B6%D0%B5%D0%B1%D0%BD%D0%B0%D1%8F:UpdateProfile
[Mon Feb 13 20:01:08 2012] [error] [client 127.0.0.1] File does not exist: C:/AppServ/OpenServerSites/mediawiki.local/www/favicon.ico
[Mon Feb 13 20:01:43 2012] [error] [client 127.0.0.1] (20024)The given path is misformatted or contained invalid characters: Cannot map POST /index.php/%D0%A1%D0%BB%D1%83%D0%B6%D0%B5%D0%B1%D0%BD%D0%B0%D1%8F:UpdateProfile HTTP/1.1 to file, referer: http://mediawiki.local/index.php/%D0%A1%D0%BB%D1%83%D0%B6%D0%B5%D0%B1%D0%BD%D0%B0%D1%8F:UpdateProfile
PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\AppServ\php5\ext\php_curl.dll' - Не найдена указанная процедура.
 in Unknown on line 0
PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\AppServ\php5\ext\php_fileinfo.dll' - Не найдена указанная процедура.
PHP Warning:  PHP Startup: gd: Unable to initialize module
Module compiled with module API=20090626, debug=0, thread-safety=1
PHP    compiled with module API=20060613, debug=0, thread-safety=1
These options need to match
PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\AppServ\php5\ext\php_intl.dll' - Не найдена указанная процедура.
PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\AppServ\php5\ext\php_mbstring.dll' - Не найдена указанная процедура.
PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\AppServ\php5\ext\php_mysql.dll' - Не найдена указанная процедура.
PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\AppServ\php5\ext\php_openssl.dll' - Не найдена указанная процедура.
PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\AppServ\php5\ext\php_pdo_mysql.dll' - Не найдена указанная процедура.
PHP Strict Standards:  date(): It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Asia/Dubai' for '4.0/no DST' instead in S:\server\system\sendmail.php on line 10
PHP Strict Standards:  date(): It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Asia/Dubai' for '4.0/no DST' instead in S:\server\system\sendmail.php on line 22
[Mon Feb 13 20:02:06 2012] [error] [client 127.0.0.1] File does not exist: C:/AppServ/OpenServerSites/mediawiki.local/www/favicon.ico
Re: %phpdir% и AppServ , проблемы
Максим » 13 фев 2012, 21:46
%phpdir% там прекрасный, и правильный он там хотя бы потому, что начинается с имени виртуального диска, а не с системного C:\. Это вы видимо что-то намутили в php.ini
