У меня есть сайт,там есть 3 ссылки,все работало отлично,но я накосячил с .htaccess и перестала одна ссылка работать,я удалил htaccess ,так все осталось,поменял названия домена,вроде бы прекратилась ошибка,но когда возвращаюсь на домен news.ru и нажимаю на 1 ссылку,то пишет ошибку ,если на 2 то нет ошибки,хоть адресс правильно написан
Вот лог:
[Mon Dec 12 17:42:23 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Mon Dec 12 17:42:24 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Mon Dec 12 17:42:24 2016] [notice] Apache/2.2.31 (Win32) mod_ssl/2.2.31 OpenSSL/1.0.1p configured -- resuming normal operations
[Mon Dec 12 17:42:24 2016] [notice] Server built: Jul 16 2015 11:30:50
[Mon Dec 12 17:42:24 2016] [notice] Parent: Created child process 5640
[Mon Dec 12 17:42:24 2016] [notice] Disabled use of AcceptEx() WinSock2 API
[Mon Dec 12 17:42:25 2016] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Mon Dec 12 17:42:25 2016] [notice] Child 5640: Child process is running
[Mon Dec 12 17:42:25 2016] [notice] Child 5640: Acquired the start mutex.
[Mon Dec 12 17:42:25 2016] [notice] Child 5640: Starting 32 worker threads.
[Mon Dec 12 17:42:25 2016] [notice] Child 5640: Listening on port 443.
[Mon Dec 12 17:42:25 2016] [notice] Child 5640: Listening on port 80.
[Mon Dec 12 17:44:03 2016] [error] [client 127.0.0.1] (20023)The given path was above the root path: Cannot map GET /C:/OpenServer/OpenServer/domains/News.ru/ HTTP/1.1 to file, referer: http://news.ru/
[Mon Dec 12 17:44:11 2016] [error] [client 127.0.0.1] (20023)The given path was above the root path: Cannot map GET /C:/OpenServer/OpenServer/domains/News.ru/index.php HTTP/1.1 to file
[Mon Dec 12 17:48:28 2016] [error] [client 127.0.0.1] (20023)The given path was above the root path: Cannot map GET /C:/OpenServer/OpenServer/domains/News.ru/ HTTP/1.1 to file, referer: http://news.ru/article.php?id=1
А вот и ошибка:
Access forbidden!
You don't have permission to access the requested directory. There is either no index document or the directory is read-protected.
Error 403
news.ru
12/12/16 17:56:15
Apache
Я ДУМАЮ ВСЕ ДЕЛО В HTACCESS Может КЭШ ОСТАЛСЯ НА ОПЕН СЕРВЕРЕ, + на домене все работает (на хосте).Пробовал сделать заводские настройки не помогли( я даже папку temp удалил точнее данные от туда
- Текущее время: 25 окт 2026, 05:54
