[Xdebug] zend_extension="c:/openserver/modules/php/PHP-5.6-x64/ext/php_xdebug.dll" xdebug.auto_trace = 0 xdebug.collect_includes = 1 xdebug.dump.REQUEST = * xdebug.dump.SESSION = * xdebug.dump.SERVER = REMOTE_ADDR,REQUEST_METHOD xdebug.dump_globals = 1 xdebug.dump_once = 1 xdebug.dump_undefined = 1 xdebug.extended_info = 1 xdebug.idekey = "PHPSTORM" xdebug.max_nesting_level = 256 xdebug.overload_var_dump = 1 xdebug.profiler_enable = 0 xdebug.profiler_enable_trigger = 1 xdebug.profiler_output_dir="c:/openserver/userdata/temp/xdebug/" xdebug.profiler_output_name = "cachegrind.out.%H%R" xdebug.remote_enable = 1 xdebug.remote_handler = "dbgp" xdebug.remote_host = "localhost" xdebug.remote_port = 9002 xdebug.trace_output_dir = "c:/openserver/userdata/temp/xdebug/" xdebug.var_display_max_children = 256 xdebug.var_display_max_depth = 16 xdebug.remote_autostart=1Настройки:
http://i.stack.imgur.com/g5qXM.png
Waiting for incoming connection with ide key 'PHPSTORM':
http://i.stack.imgur.com/Fh652.png
Пробовал менять порты, не помогло
