Версия Программы 5.1.1, Apach 2.4, php 5.5
Пытаюсь установить Composer как описано в руководстве пользователя:
http://open-server.ru/docs/#rabota-s-composer
После запуска composer init появляется сообщение:
Fatal error: require(): Failed opening required 'phar://composer.phar/bin/composer'
(include_path='.;C:\OpenServer\modules\php\PHP-5.5;C:\OpenServer\modules\php\PHP-5.5\PEAR\pear') in
C:\OpenServer\modules\php\PHP-5.5\composer.phar on line 15
Скриншот:
http://joxi.ru/Q2KqojPs4byBrj
Скопировал composer.phar в каталог с localhost, после запуска: composer init
Fatal error: Uncaught exception 'ErrorException' with message 'php_uname() has been disabled for security reasons' in phar://D:/WebServers/home/localhost/composer.phar/vendor/symfony/console/Symfony/Component/Console/Output/ConsoleOutput.php on line 111
ErrorException: php_uname() has been disabled for security reasons in phar://D:/WebServers/home/localhost/composer.phar/vendor/symfony/console/Symfony/Component/Console/Output/ConsoleOutput.php on line 111
Call Stack:
0.0020 127960 1. {main}() C:\OpenServer\modules\php\PHP-5.5\composer.phar:0
0.0080 246360 2. require('phar://D:/WebServers/home/localhost/composer.phar/bin/composer') C:\OpenServer\modules\php\PHP-5.5\composer.phar:15
0.0640 2196872 3. Composer\Console\Application->run() phar://D:/WebServers/home/localhost/composer.phar/bin/composer:43
0.0720 2422416 4. Symfony\Component\Console\Output\ConsoleOutput->__construct() phar://D:/WebServers/home/localhost/composer.phar/src/Composer/Console/Application.php:80
0.0720 2422496 5. Symfony\Component\Console\Output\ConsoleOutput->hasStdoutSupport() phar://D:/WebServers/home/localhost/composer.phar/vendor/symfony/console/Symfony/Component/Console/Output/ConsoleOutput.php:47
0.0720 2422576 6. php_uname() phar://D:/WebServers/home/localhost/composer.phar/vendor/symfony/console/Symfony/Component/Console/Output/ConsoleOutput.php:111
0.0720 2423064 7. Composer\Util\ErrorHandler::handle() phar://D:/WebServers/home/localhost/composer.phar/vendor/symfony/console/Symfony/Component/Console/Output/ConsoleOutput.php:111
Скриншот:
http://joxi.ru/Y2LDo8PF9we926
С чем это связано и как исправить?
[upd=1415354856][/upd]
Тема закрыта ... Проблема была связана со строкой
disable_functions в php.ini
- Текущее время: 26 апр 2024, 11:19
