Уж очень прошу!Redee писал(а):щас накидаю скриншотов!)
- Текущее время: 27 апр 2024, 03:55
[Xdebug] zend_extension="%sprogdir%/modules/php/%phpdriver%/ext/php_xdebug.dll" xdebug.auto_trace = 0 ;xdebug.collect_includes = 1 ;xdebug.collect_params = 0 ;xdebug.collect_return = 0 ;xdebug.collect_vars = 0 xdebug.default_enable = 0 ;xdebug.dump.SERVER = REMOTE_ADDR,REQUEST_METHOD ;xdebug.dump.SERVER = REMOTE_ADDR,REQUEST_METHOD ;xdebug.dump.COOKIE = "" ;xdebug.dump.FILES = "" ;xdebug.dump.GET = "" ;xdebug.dump.POST = "" ;xdebug.dump.REQUEST = "" ;xdebug.dump.SERVER = "" ;xdebug.dump.SESSION = "" ;xdebug.dump_globals = 1 ;xdebug.dump_once = 1 ;xdebug.dump_undefined = 0 ;xdebug.extended_info = 1 ;xdebug.file_link_format = "" xdebug.idekey = "PHPSTORM" ;xdebug.manual_url = "http://www.php.net" ;xdebug.max_nesting_level = 100 ;xdebug.overload_var_dump = 1 ;xdebug.profiler_append = 0 xdebug.profiler_enable = 0 xdebug.profiler_enable_trigger = 1 xdebug.profiler_output_dir="%sprogdir%/userdata/temp/xdebug/" xdebug.profiler_output_name = "cachegrind.out.%H%R" ;xdebug.remote_autostart = 0 xdebug.remote_enable = 1 xdebug.remote_handler = "dbgp" xdebug.remote_host = "localhost" ;xdebug.remote_log = "none" ;xdebug.remote_mode = "req" xdebug.remote_port = 9000 ;xdebug.show_exception_trace = 0 ;xdebug.show_local_vars = 0 ;xdebug.show_mem_delta = 0 ;xdebug.trace_format = 0 ;xdebug.trace_options = 0 xdebug.trace_output_dir = "%sprogdir%/userdata/temp/xdebug/" ;xdebug.trace_output_name = "trace.%H%R" ;xdebug.var_display_max_children = 128 ;xdebug.var_display_max_data = 512 ;xdebug.var_display_max_depth = 3з.ы. долго ковырялся в пакетной обработке фотошопа, но +experience ))
[Xdebug] zend_extension="%sprogdir%/modules/php/%phpdriver%/ext/php_xdebug.dll" xdebug.default_enable = 0 xdebug.auto_trace = 0 xdebug.collect_includes = 1 ;xdebug.collect_params = 4 ;xdebug.collect_return = 1 ;xdebug.collect_assignments = 1 ;xdebug.collect_vars = 1 xdebug.dump.REQUEST = * xdebug.dump.SESSION = * xdebug.dump.SERVER = REMOTE_ADDR,REQUEST_METHOD ;xdebug.dump.COOKIE = ;xdebug.dump.FILES = ;xdebug.dump.GET = ;xdebug.dump.POST = xdebug.dump_globals = 1 xdebug.dump_once = 1 xdebug.dump_undefined = 1 xdebug.extended_info = 0 ;xdebug.file_link_format = "" ;xdebug.idekey = "" ;xdebug.manual_url = "http://www.php.net" xdebug.max_nesting_level = 256 xdebug.overload_var_dump = 1 ;xdebug.profiler_append = 1 xdebug.profiler_enable = 0 xdebug.profiler_enable_trigger = 1 xdebug.profiler_output_dir="%sprogdir%/userdata/temp/xdebug/" xdebug.profiler_output_name = "cachegrind.out.%H%R" ;xdebug.remote_autostart = 0 xdebug.remote_enable = 1 xdebug.remote_handler = "dbgp" xdebug.remote_host = 127.0.0.1 xdebug.remote_log = "%sprogdir%/userdata/temp/xdebug/xdebug.log" ;xdebug.remote_mode = "req" xdebug.remote_port = 9000 ;xdebug.scream = 1 ;xdebug.show_exception_trace = 0 ;xdebug.show_local_vars = 1 ;xdebug.show_mem_delta = 1 ;xdebug.trace_format = 1 ;xdebug.trace_options = 1 xdebug.trace_output_dir = "%sprogdir%/userdata/temp/xdebug/" ;xdebug.trace_output_name = "trace.%H%R" ;xdebug.var_display_max_children = 128 ;xdebug.var_display_max_data = 512 ;xdebug.var_display_max_depth = 3
Действительно. Уже под Atom решил попробовать снова xdebug и обнаружил, что с отключенной опцией он работает очень странно, например, может отлавливать точки в соседних доменах, а в том файле где стоит точка вообще не работает! Поменял и сразу увидел положительный эффект.Максим писал(а):Соглядатай, в соседней теме писали что может быть виновато
поставьте равным единице.
zend_extension="%sprogdir%/modules/php/%phpdriver%/ext/php_xdebug-2.4.0rc4-5.5-vc11.dll" xdebug.remote_host = 127.0.0.1 xdebug.remote_connect_back = 1 xdebug.remote_port = 10000 xdebug.remote_handler = "dbgp" xdebug.remote_mode = "req" ;xdebug.remote_autostart = 1 xdebug.default_enable = 1 xdebug.idekey = "atom-xdebug" xdebug.remote_enable = 1 xdebug.extended_info = 1 xdebug.auto_trace = 0 xdebug.collect_includes = 1 xdebug.dump.REQUEST = * xdebug.dump.SESSION = * xdebug.dump.SERVER = REMOTE_ADDR,REQUEST_METHOD xdebug.dump_globals = 1 xdebug.dump_once = 1 xdebug.dump_undefined = 1 xdebug.max_nesting_level = 256 xdebug.overload_var_dump = 1 xdebug.profiler_enable = 0 xdebug.profiler_enable_trigger = 1 xdebug.profiler_output_dir="%sprogdir%/userdata/temp/xdebug/" xdebug.profiler_output_name = "cachegrind.out.%H%R" xdebug.remote_log = "%sprogdir%/userdata/temp/xdebug/xdebug.log" xdebug.trace_output_dir = "%sprogdir%/userdata/temp/xdebug/"
