В логе вот.
2013-05-25 23:28:01 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2013-05-25 23:28:02 3832 [Note] Plugin 'FEDERATED' is disabled.
2013-05-25 23:28:02 3832 [Note] InnoDB: The InnoDB memory heap is disabled
2013-05-25 23:28:02 3832 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2013-05-25 23:28:02 3832 [Note] InnoDB: Compressed tables use zlib 1.2.3
2013-05-25 23:28:02 3832 [Note] InnoDB: CPU does not support crc32 instructions
2013-05-25 23:28:02 3832 [Note] InnoDB: Initializing buffer pool, size = 10.0M
2013-05-25 23:28:02 3832 [Note] InnoDB: Completed initialization of buffer pool
2013-05-25 23:28:02 3832 [Note] InnoDB: Highest supported file format is Barracuda.
2013-05-25 23:28:03 3832 [Note] InnoDB: 128 rollback segment(s) are active.
2013-05-25 23:28:03 3832 [Note] InnoDB: Waiting for purge to start
2013-05-25 23:28:03 3832 [Note] InnoDB: 1.2.10 started; log sequence number 59814629
2013-05-25 23:28:03 3832 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
2013-05-25 23:28:03 3832 [Note] - '0.0.0.0' resolves to '0.0.0.0';
2013-05-25 23:28:03 3832 [Note] Server socket created on IP: '0.0.0.0'.
2013-05-25 23:28:03 3832 [Note] Event Scheduler: Loaded 0 events
2013-05-25 23:28:03 3832 [Note] ...\modules\database\MySQL-5.6.10\bin\mysqld.exe: ready for connections.
Version: '5.6.10-log' socket: '' port: 3306 MySQL Community Server (GPL)
Упало два сайта на СМС. Другие работают. Чо за беда? Не могу нагуглить почему то
- Текущее время: 26 апр 2024, 13:14
