- Текущее время: 20 ноя 2026, 20:52
В итоге ошибка в браузере bad gateway. Удаляю настройки. Всё нормально работает.[mbstring]
mbstring.func_overload=2
mbstring.internal_encoding=UTF-8
*вместо звездочек название сайта2020/04/26 11:57:58 [error] 4080#15344: *1 WSARecv() failed (10054: An existing connection was forcibly closed by the remote host) while reading response header from upstream, client: 127.0.0.1, server: ***.loc, request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:8080/", host: "***.loc"
[Sun Apr 26 12:10:42.266305 2020] [ssl:warn] [pid 14816:tid 116] AH01909: rimera.loc:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:42.269305 2020] [ssl:warn] [pid 14816:tid 116] AH01909: httpd:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:42.370306 2020] [ssl:warn] [pid 14816:tid 116] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:42.441306 2020] [mpm_winnt:notice] [pid 14816:tid 116] AH00455: Apache/2.4.43 (Win64) OpenSSL/1.1.1f configured -- resuming normal operations [Sun Apr 26 12:10:42.441306 2020] [mpm_winnt:notice] [pid 14816:tid 116] AH00456: Apache Lounge VC15 Server built: Apr 1 2020 11:30:24 [Sun Apr 26 12:10:42.441306 2020] [core:notice] [pid 14816:tid 116] AH00094: Command line: 'C:\\ospanel536\\modules\\http\\Apache_2.4-PHP_7.2-7.4\\bin\\httpd.exe -d C:/OSPanel536/modules/http/Apache_2.4-PHP_7.2-7.4 -f c:\\ospanel536\\modules\\http\\Apache_2.4-PHP_7.2-7.4\\conf\\httpd.conf' [Sun Apr 26 12:10:42.456306 2020] [mpm_winnt:notice] [pid 14816:tid 116] AH00418: Parent: Created child process 14468 [Sun Apr 26 12:10:43.432671 2020] [ssl:warn] [pid 14468:tid 140] AH01909: rimera.loc:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:43.435671 2020] [ssl:warn] [pid 14468:tid 140] AH01909: httpd:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:43.518670 2020] [ssl:warn] [pid 14468:tid 140] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:43.596678 2020] [mpm_winnt:notice] [pid 14468:tid 140] AH00354: Child: Starting 150 worker threads. [Sun Apr 26 12:10:57.309878 2020] [mpm_winnt:notice] [pid 14816:tid 116] AH00428: Parent: child process 14468 exited with status 3221225477 -- Restarting. [Sun Apr 26 12:10:57.415876 2020] [ssl:warn] [pid 14816:tid 116] AH01909: rimera.loc:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:57.416877 2020] [ssl:warn] [pid 14816:tid 116] AH01909: nasos.loc:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:57.417953 2020] [ssl:warn] [pid 14816:tid 116] AH01909: httpd:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:57.421951 2020] [ssl:warn] [pid 14816:tid 116] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:57.487903 2020] [mpm_winnt:notice] [pid 14816:tid 116] AH00455: Apache/2.4.43 (Win64) OpenSSL/1.1.1f configured -- resuming normal operations [Sun Apr 26 12:10:57.487903 2020] [mpm_winnt:notice] [pid 14816:tid 116] AH00456: Apache Lounge VC15 Server built: Apr 1 2020 11:30:24 [Sun Apr 26 12:10:57.487903 2020] [core:notice] [pid 14816:tid 116] AH00094: Command line: 'C:\\ospanel536\\modules\\http\\Apache_2.4-PHP_7.2-7.4\\bin\\httpd.exe -d C:/OSPanel536/modules/http/Apache_2.4-PHP_7.2-7.4 -f c:\\ospanel536\\modules\\http\\Apache_2.4-PHP_7.2-7.4\\conf\\httpd.conf' [Sun Apr 26 12:10:57.493966 2020] [mpm_winnt:notice] [pid 14816:tid 116] AH00418: Parent: Created child process 14256 [Sun Apr 26 12:10:58.428946 2020] [ssl:warn] [pid 14256:tid 540] AH01909: rimera.loc:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:58.430946 2020] [ssl:warn] [pid 14256:tid 540] AH01909: nasos.loc:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:58.431876 2020] [ssl:warn] [pid 14256:tid 540] AH01909: httpd:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:58.514288 2020] [ssl:warn] [pid 14256:tid 540] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name [Sun Apr 26 12:10:58.587288 2020] [mpm_winnt:notice] [pid 14256:tid 540] AH00354: Child: Starting 150 worker threads.
mbstring.func_overload string
Внимание
Данный функционал объявлен УСТАРЕВШИМ, начиная с PHP 7.2.0 его использование крайне не рекомендовано.
Скажите это разработчикам BitrixМаксим писал(а): ↑26 апр 2020, 15:52 ruslan2243, вот что делает безграмотность и неосведомлённость. Зачем вы используете на PHP 7.2 эту функцию? Вот вам немного выдержки из документации к PHP:
Внимание
Решения пока не нашли? История та же самая.ruslan2243 писал(а): ↑27 апр 2020, 11:34Скажите это разработчикам Bitrix
И статус у неё deprecated, значит он еще полностью в рабочем состоянии и выпилят его лишь в следующих релизах, может быть, этот статус может еще очень долго переходить от версии к версии. Это пишут, чтобы разработчики начали потихоньку переписывать свой код с упором на будущее.
upxF0x9Fx92x83 писал(а): ↑20 апр 2020, 04:56 Максим, в первую очередь спасибо за программу и её активную поддержку!
В версиях 5.3.6 и 5.3.7 (в ранних не проверял) есть проблема в конфигурации Apache 2.4 + PHP 7.2 - при mbstring.func_overload = "2" php-страницы не загружаются (apach постоянно перезапускается с сообщением AH00428: Parent: child process 5188 exited with status 3221225477 -- Restarting), а в логе windows появляется сообщение о проблеме с модулем php_soap.dll. Выключение модуля soap, или использование nginx вместо apache, конечно, решает проблему, но хотелось бы и чтобы дефолтная конфигурация работала
Я понимаю, что mbstring.func_overload deprecated в php 7.2, но не удалось нагуглить есть ли заявленные проблемы для такой связки модулей.
Спасибо.
