- Текущее время: 16 июн 2025, 02:04
@echo OFF setlocal enableextensions enabledelayedexpansion set OPENSSL_CONF=%realprogdir%\modules\http\%httpdriver%\conf\openssl.cnf set PATH=%PATH%;%realprogdir%\modules\http\%httpdriver%\bin set CERTS_PATH=%realprogdir%\userdata\config\cert_files set days=3660 set key_bits=2048 set dname=server set generic_ips=127.0.0.1 0.0.0.0 rem Введите сюда IP компьютера на котором установлен сервер через пробел set my_ip=192.168.4.48 192.168.56.1 echo [trust_cert] > %dname%.cnf echo subjectAltName=@alt_names >> %dname%.cnf echo keyUsage=digitalSignature,keyEncipherment,dataEncipherment >> %dname%.cnf echo extendedKeyUsage=serverAuth,clientAuth >> %dname%.cnf echo [alt_names] >> %dname%.cnf set /a count_ip = 1 for %%a in (%generic_ips%) do ( echo IP.!count_ip! = %%a >> %dname%.cnf set /a count_ip += 1 ) for %%b in (%my_ip%) do ( echo IP.!count_ip! = %%b >> %dname%.cnf set /a count_ip += 1 ) set /a count = 1 for /f "tokens=*" %%G in ('dir %realprogdir%\domains\ /b') do ( echo DNS.!count! = %%G >> %dname%.cnf set /a count += 1 echo DNS.!count! = www.%%G >> %dname%.cnf set /a count += 1 ) openssl genrsa -out %CERTS_PATH%\%dname%.key %key_bits% openssl req -sha256 -new -utf8 -key %CERTS_PATH%\%dname%.key -out %dname%.csr -subj /emailAddress="info\@ospanel\.io"/C=RU/stateOrProvinceName="Russian Federation"/L=Moscow/O="Open Server Panel"/OU=Software/CN=%dname% openssl x509 -sha256 -req -days %days% -in %dname%.csr -extfile %dname%.cnf -extensions trust_cert -CA %CERTS_PATH%\rootCA.crt -CAkey %CERTS_PATH%\rootCA.key -out %CERTS_PATH%\%dname%.crt openssl x509 -in %CERTS_PATH%\%dname%.crt -noout -purpose del %dname%.csr del %dname%.cnf
#-----------------------------------------------# # Начало блока конфигурации HTTPS хоста #-----------------------------------------------# <IfModule ssl_module> <VirtualHost *:%httpsport%> DocumentRoot "%hostdir%" ServerName "%host%" ServerAlias "%host%" %aliases% ScriptAlias /cgi-bin/ "%hostdir%/cgi-bin/" SSLEngine on #Header always set Strict-Transport-Security "max-age=94608000" #SSLCACertificateFile "%sprogdir%/userdata/config/cert_files/ca.crt" #SSLCertificateChainFile "%sprogdir%/userdata/config/cert_files/CertificateChain.crt" SSLCertificateFile "%sprogdir%/userdata/config/cert_files/server.crt" SSLCertificateKeyFile "%sprogdir%/userdata/config/cert_files/server.key" SetEnvIf User-Agent ".*MSIE [1-5].*" \ nokeepalive ssl-unclean-shutdown \ downgrade-1.0 force-response-1.0 SetEnvIf User-Agent ".*MSIE [6-9].*" \ ssl-unclean-shutdown <FilesMatch "\.(cgi|shtml|phtml|php)$"> SSLOptions +StdEnvVars </FilesMatch> <Directory "%hostdir%/cgi-bin/"> SSLOptions +StdEnvVars </Directory> </VirtualHost> </IfModule> #-----------------------------------------------# # Конец блока конфигурации HTTPS хоста #-----------------------------------------------#На ПК сертификат подхватывается, на устройствах - нет
Тоже с этой фигней мучаюсь уже задолбалсяaolko писал(а): ↑09 ноя 2023, 12:02 Модифицировал батник и конфиг:@echo OFF setlocal enableextensions enabledelayedexpansion set OPENSSL_CONF=%realprogdir%\modules\http\%httpdriver%\conf\openssl.cnf set PATH=%PATH%;%realprogdir%\modules\http\%httpdriver%\bin set CERTS_PATH=%realprogdir%\userdata\config\cert_files set days=3660 set key_bits=2048 set dname=server set generic_ips=127.0.0.1 0.0.0.0 rem Введите сюда IP компьютера на котором установлен сервер через пробел set my_ip=192.168.4.48 192.168.56.1 echo [trust_cert] > %dname%.cnf echo subjectAltName=@alt_names >> %dname%.cnf echo keyUsage=digitalSignature,keyEncipherment,dataEncipherment >> %dname%.cnf echo extendedKeyUsage=serverAuth,clientAuth >> %dname%.cnf echo [alt_names] >> %dname%.cnf set /a count_ip = 1 for %%a in (%generic_ips%) do ( echo IP.!count_ip! = %%a >> %dname%.cnf set /a count_ip += 1 ) for %%b in (%my_ip%) do ( echo IP.!count_ip! = %%b >> %dname%.cnf set /a count_ip += 1 ) set /a count = 1 for /f "tokens=*" %%G in ('dir %realprogdir%\domains\ /b') do ( echo DNS.!count! = %%G >> %dname%.cnf set /a count += 1 echo DNS.!count! = www.%%G >> %dname%.cnf set /a count += 1 ) openssl genrsa -out %CERTS_PATH%\%dname%.key %key_bits% openssl req -sha256 -new -utf8 -key %CERTS_PATH%\%dname%.key -out %dname%.csr -subj /emailAddress="info\@ospanel\.io"/C=RU/stateOrProvinceName="Russian Federation"/L=Moscow/O="Open Server Panel"/OU=Software/CN=%dname% openssl x509 -sha256 -req -days %days% -in %dname%.csr -extfile %dname%.cnf -extensions trust_cert -CA %CERTS_PATH%\rootCA.crt -CAkey %CERTS_PATH%\rootCA.key -out %CERTS_PATH%\%dname%.crt openssl x509 -in %CERTS_PATH%\%dname%.crt -noout -purpose del %dname%.csr del %dname%.cnf#-----------------------------------------------# # Начало блока конфигурации HTTPS хоста #-----------------------------------------------# <IfModule ssl_module> <VirtualHost *:%httpsport%> DocumentRoot "%hostdir%" ServerName "%host%" ServerAlias "%host%" %aliases% ScriptAlias /cgi-bin/ "%hostdir%/cgi-bin/" SSLEngine on #Header always set Strict-Transport-Security "max-age=94608000" #SSLCACertificateFile "%sprogdir%/userdata/config/cert_files/ca.crt" #SSLCertificateChainFile "%sprogdir%/userdata/config/cert_files/CertificateChain.crt" SSLCertificateFile "%sprogdir%/userdata/config/cert_files/server.crt" SSLCertificateKeyFile "%sprogdir%/userdata/config/cert_files/server.key" SetEnvIf User-Agent ".*MSIE [1-5].*" \ nokeepalive ssl-unclean-shutdown \ downgrade-1.0 force-response-1.0 SetEnvIf User-Agent ".*MSIE [6-9].*" \ ssl-unclean-shutdown <FilesMatch "\.(cgi|shtml|phtml|php)$"> SSLOptions +StdEnvVars </FilesMatch> <Directory "%hostdir%/cgi-bin/"> SSLOptions +StdEnvVars </Directory> </VirtualHost> </IfModule> #-----------------------------------------------# # Конец блока конфигурации HTTPS хоста #-----------------------------------------------#Разобрался конечно немного с настройкой серверов, но легче все же когда это делают за тебя как наhttps://sysadmin.com.ua/services/server
На ПК сертификат подхватывается, на устройствах - нет![]()
