Добрый день,
выкидывает вот такую ошибку при сохранении изменений в фраймворке шаблона.
Warning: Unknown: Input variables exceeded 1000. To increase the limit change max_input_vars in php.ini. in Unknown on line 0
Error displaying the error page: Application Instantiation Error: Failed to start the session because headers have already been sent by "" at line 0.
Обратился в суппорт производителя , ответили так
our values seem a little too high, usually max_input_vars = 10000 is more than enough for template parameters to be saved. The default upload parameters are fine most of the time but you may want to change them depending on your needs (uploading big files, etc).
PHP default values are too low for a dynamic site such as Joomla. In particular, the amount of incoming data rows accepted back from your browser is too low for the number of parameters available on our templates. This is what the max_input_vars parameter does.
The error appears on some hosting systems because PHP is configured with very low values, the following guide explains how to configure PHP to work better with your Joomla site: http://www.joomlaxtc.com/support/tem...ave-parameters
Please note your hosting company might use a different method to apply these changes, ask your hosting company for the right procedure.
Я записал видио, смотреть тут https://youtu.be/bCw3NXMk-Ac
У меня стоит в ини
; max_input_vars = 10000
memory_limit = 1536M
upload_max_filesize = 100M
post_max_size = 100M
Напишите кто сталкивался с такой проблемой и как решить ее.
Спасибо
- Текущее время: 20 июн 2025, 22:56
