Пользовался я Open Server 5 и все было хорошо.
Решил вчера поставить Open Server 5.1.1 и что-то никак мои сайты не открываются.
Хром говорит "Oops! Google Chrome could not find test",
В логах Apache отладка
[Thu Jul 10 17:31:52.897915 2014] [ssl:warn] [pid 6940:tid 240] AH01909: test:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:52.899915 2014] [ssl:warn] [pid 6940:tid 240] AH01909: resurs:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:52.899915 2014] [ssl:warn] [pid 6940:tid 240] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:52.899915 2014] [ssl:warn] [pid 6940:tid 240] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Jul 10 17:31:52.962919 2014] [:notice] [pid 6940:tid 240] mod_bw : Memory Allocated 0 bytes (each conf takes 40 bytes)
[Thu Jul 10 17:31:52.962919 2014] [:notice] [pid 6940:tid 240] mod_bw : Version 0.92 - Initialized [0 Confs]
[Thu Jul 10 17:31:52.962919 2014] [:notice] [pid 6940:tid 240] mod_bw : Supported resolution for Timers [ Min: 1 Max: 1000000 ]
[Thu Jul 10 17:31:52.962919 2014] [:notice] [pid 6940:tid 240] mod_bw : Enabling High resolution timers [ 1 ms ]
[Thu Jul 10 17:31:53.133929 2014] [ssl:warn] [pid 6940:tid 240] AH01909: test:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:53.133929 2014] [ssl:warn] [pid 6940:tid 240] AH01909: resurs:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:53.134929 2014] [ssl:warn] [pid 6940:tid 240] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:53.134929 2014] [ssl:warn] [pid 6940:tid 240] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Jul 10 17:31:53.373942 2014] [mpm_winnt:notice] [pid 6940:tid 240] AH00455: Apache/2.4.9 (Win32) OpenSSL/1.0.1h configured -- resuming normal operations
[Thu Jul 10 17:31:53.373942 2014] [mpm_winnt:notice] [pid 6940:tid 240] AH00456: Apache Lounge VC11 Server built: Mar 16 2014 12:13:13
[Thu Jul 10 17:31:53.373942 2014] [core:notice] [pid 6940:tid 240] AH00094: Command line: 'D:\\soft\\webServer\\openserver5.1.1\\OpenServer\\modules\\http\\Apache-2.4\\bin\\httpd.exe -d D:/soft/webServer/openserver5.1.1/OpenServer/modules/http/Apache-2.4 -f D:\\soft\\webServer\\openserver5.1.1\\OpenServer\\userdata\\temp\\config\\httpd.conf'
[Thu Jul 10 17:31:53.390943 2014] [mpm_winnt:notice] [pid 6940:tid 240] AH00418: Parent: Created child process 5708
[Thu Jul 10 17:31:54.162987 2014] [ssl:warn] [pid 5708:tid 252] AH01909: test:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:54.163988 2014] [ssl:warn] [pid 5708:tid 252] AH01909: resurs:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:54.163988 2014] [ssl:warn] [pid 5708:tid 252] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:54.164988 2014] [ssl:warn] [pid 5708:tid 252] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Jul 10 17:31:54.228991 2014] [:notice] [pid 5708:tid 252] mod_bw : Memory Allocated 0 bytes (each conf takes 40 bytes)
[Thu Jul 10 17:31:54.228991 2014] [:notice] [pid 5708:tid 252] mod_bw : Version 0.92 - Initialized [0 Confs]
[Thu Jul 10 17:31:54.228991 2014] [:notice] [pid 5708:tid 252] mod_bw : Supported resolution for Timers [ Min: 1 Max: 1000000 ]
[Thu Jul 10 17:31:54.228991 2014] [:notice] [pid 5708:tid 252] mod_bw : Enabling High resolution timers [ 1 ms ]
[Thu Jul 10 17:31:54.418002 2014] [ssl:warn] [pid 5708:tid 252] AH01909: test:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:54.419002 2014] [ssl:warn] [pid 5708:tid 252] AH01909: resurs:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:54.419002 2014] [ssl:warn] [pid 5708:tid 252] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 10 17:31:54.420002 2014] [ssl:warn] [pid 5708:tid 252] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Jul 10 17:31:54.586012 2014] [mpm_winnt:notice] [pid 5708:tid 252] AH00354: Child: Starting 32 worker threads.
Пока пользуюсь Open Server 5, но хотелось бы разобраться с новой версией на будущее
- Текущее время: 22 июн 2025, 16:02
