CREATE TABLE IF NOT EXISTS `users` ( `id` int(11) NOT NULL AUTO_INCREMENT, `login` varchar(255) COLLATE utf8_unicode_ci NOT NULL, `pass` varchar(255) COLLATE utf8_unicode_ci NOT NULL, `mail` varchar(255) COLLATE utf8_unicode_ci NOT NULL, `age` tinyint(4) NOT NULL DEFAULT '18', `active` tinyint(1) NOT NULL DEFAULT '0', `hash` varchar(255) COLLATE utf8_unicode_ci NOT NULL, `acces` tinyint(1) NOT NULL DEFAULT '0', PRIMARY KEY (`id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci AUTO_INCREMENT=16 ; -- -- Дамп данных таблицы `users` -- INSERT INTO `users` (`id`, `login`, `pass`, `mail`, `age`, `active`, `hash`, `acces`) VALUES (5, 'Serg', '333333', '[email protected]', 22, 0, '', 0), (9, 'Kon', 'asdfggh', '[email protected]', 44, 0, '', 0), (13, 'Kostya', '183674536', '[email protected]', 14, 0, '', 0), (15, 'admin', 'CB3Q/CSYBHA4E', '[email protected]', 29, 1, 'CBJhZOpeuJPsw', 5);и все хорошо импортируется.
А при экспорте из опен сервера создается с таким содержанием:
<!-- PMA-SQL-ERROR --> <div class="error"><h1>Ошибка</h1> <p><strong>SQL-запрос:</strong> <a href="tbl_sql.php?sql_query=SET+time_zone+%3D+%22%2B00%3A00%22&show_query=1&db=sitephp&table=users&token=2a7fd6b301c8250411223c2972537692"><span class="nowrap"><img src="themes/dot.gif" title="Изменить" alt="Изменить" class="icon ic_b_edit" /></span></a> </p> <p> <span class="syntax"><span class="inner_sql"><a href="./url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fen%2Fset.html&token=2a7fd6b301c8250411223c2972537692" target="mysql_doc"><span class="syntax_alpha syntax_alpha_reservedWord">SET</span></a> <span class="syntax_alpha syntax_alpha_identifier">time_zone</span> <a href="./url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fen%2Fcomparison-operators.html%23operator_equal&token=2a7fd6b301c8250411223c2972537692" target="mysql_doc"><span class="syntax_punct">=</span></a> <span class="syntax_quote syntax_quote_double">"+00:00"</span></span></span> </p> <p> <strong>Ответ MySQL: </strong><a href="./url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fen%2Ferror-messages-server.html&token=2a7fd6b301c8250411223c2972537692" target="mysql_doc"><img src="themes/dot.gif" title="Документация" alt="Документация" class="icon ic_b_help" /></a> </p> <code> #1298 - Unknown or incorrect time zone: '+00:00' </code><br /> </div>и этот файл ни могу импортировать выдает ошибку. Может нужно сделать каки-то настройки и если нужно, то какие?
