- Текущее время: 18 июн 2025, 02:11
odules\\system\\html\\openserver\\phpmyadmin\\./themes/darkwolf/', ) .\libraries\classes\ThemeManager.php#79: PhpMyAdmin\ThemeManager->loadThemes() .\libraries\classes\ThemeManager.php#121: PhpMyAdmin\ThemeManager->__construct() .\libraries\classes\ThemeManager.php#385: PhpMyAdmin\ThemeManager::getInstance() .\libraries\common.inc.php#240: PhpMyAdmin\ThemeManager::initializeTheme() .\index.php#15: require_once(.\libraries\common.inc.php) Deprecation Notice in .\vendor\twig\twig\src\Node\Node.php#161 Return type of Twig\Node\Node::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice Backtrace .\vendor\composer\ClassLoader.php#444: include(.\vendor\twig\twig\src\Node\Node.php) .\vendor\composer\ClassLoader.php#322: Composer\Autoload\includeFile(string 'E:\\Soft\\OpenServer\\modules\\system\\html\\openserver\\phpmyadmin\\vendor\\composer/../twig/twig/src/Node/Node.php') Composer\Autoload\ClassLoader->loadClass(string 'Twig\\Node\\Node') .\vendor\twig\twig\src\TwigFilter.php#150: class_exists(string 'Twig\\Node\\Node') .\vendor\composer\ClassLoader.php#444: include(.\vendor\twig\twig\src\TwigFilter.php) .\vendor\composer\ClassLoader.php#322: Composer\Autoload\includeFile(string 'E:\\Soft\\OpenServer\\modules\\system\\html\\openserver\\phpmyadmin\\vendor\\composer/../twig/twig/src/TwigFilter.php') .\vendor\twig\twig\src\Extension\CoreExtension.php#214: Composer\Autoload\ClassLoader->loadClass(string 'Twig\\TwigFilter') .\vendor\twig\twig\src\ExtensionSet.php#433: Twig\Extension\CoreExtension->getFilters() .\vendor\twig\twig\src\ExtensionSet.php#423: Twig\ExtensionSet->initExtension() .\vendor\twig\twig\src\ExtensionSet.php#397: Twig\ExtensionSet->initExtensions() .\vendor\twig\twig\src\Environment.php#966: Twig\ExtensionSet->getUnaryOperators() .\vendor\twig\twig\src\Lexer.php#459: Twig\Environment->getUnaryOperators() .\vendor\twig\twig\src\Lexer.php#110: Twig\Lexer->getOperatorRegex() .\vendor\twig\twig\src\Environment.php#539: Twig\Lexer->__construct() .\vendor\twig\twig\src\Environment.php#595: Twig\Environment->tokenize() .\vendor\twig\twig\src\Environment.php#408: Twig\Environment->compileSource() .\vendor\twig\twig\src\Environment.php#381: Twig\Environment->loadClass( string '__TwigTemplate_034511bee5325c368ee003e3d97d6cb47c3e1c94ebb527bcf0b76ba7818d1ac6', string 'javascript/variables.twig', NULL, ) .\vendor\twig\twig\src\Environment.php#359: Twig\Environment->loadTemplate(string 'javascript/variables.twig') .\libraries\classes\Template.php#99: Twig\Environment->load(string 'javascript/variables.twig') .\libraries\classes\Template.php#132: PhpMyAdmin\Template->load(string 'javascript/variables') .\libraries\classes\Header.php#714: PhpMyAdmin\Template->render( string 'javascript/variables', array, ) .\libraries\classes\Header.php#193: PhpMyAdmin\Header->getVariablesForJavaScript() .\libraries\classes\Header.php#142: PhpMyAdmin\Header->addDefaultScripts() .\libraries\classes\Response.php#184: PhpMyAdmin\Header->__construct() .\libraries\classes\Response.php#215: PhpMyAdmin\Response->__construct() .\libraries\classes\Plugins\Auth\AuthenticationCookie.php#102: PhpMyAdmin\Response::getInstance() .\libraries\classes\Plugins\AuthenticationPlugin.php#275: PhpMyAdmin\Plugins\Auth\AuthenticationCookie->showLoginForm() .\libraries\common.inc.php#263: PhpMyAdmin\Plugins\AuthenticationPlugin->authenticate() .\index.php#15: require_once(.\libraries\common.inc.php) Deprecation Notice in .\vendor\twig\twig\src\Node\Node.php#166 Return type of Twig\Node\Node::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice Backtrace .\vendor\composer\ClassLoader.php#444: include(.\vendor\twig\twig\src\Node\Node.php) .\vendor\composer\ClassLoader.php#322: Composer\Autoload\includeFile(string 'E:\\Soft\\OpenServer\\modules\\system\\html\\openserver\\phpmyadmin\\vendor\\composer/../twig/twig/src/Node/Node.php') Composer\Autoload\ClassLoader->loadClass(string 'Twig\\Node\\Node') .\vendor\twig\twig\src\TwigFilter.php#150: class_exists(string 'Twig\\Node\\Node') .\vendor\composer\ClassLoader.php#444: include(.\vendor\twig\twig\src\TwigFilter.php) .\vendor\composer\ClassLoader.php#322: Composer\Autoload\includeFile(string 'E:\\Soft\\OpenServer\\modules\\system\\html\\openserver\\phpmyadmin\\vendor\\composer/../twig/twig/src/TwigFilter.php') .\vendor\twig\twig\src\Extension\CoreExtension.php#214: Composer\Autoload\ClassLoader->loadClass(string 'Twig\\TwigFilter') .\vendor\twig\twig\src\ExtensionSet.php#433: Twig\Extension\CoreExtension->getFilters() .\vendor\twig\twig\src\ExtensionSet.php#423: Twig\ExtensionSet->initExtension() .\vendor\twig\twig\src\ExtensionSet.php#397: Twig\ExtensionSet->initExtensions() .\vendor\twig\twig\src\Environment.php#966: Twig\ExtensionSet->getUnaryOperators() .\vendor\twig\twig\src\Lexer.php#459: Twig\Environment->getUnaryOperators() .\vendor\twig\twig\src\Lexer.php#110: Twig\Lexer->getOperatorRegex() .\vendor\twig\twig\src\Environment.php#539: Twig\Lexer->__construct() .\vendor\twig\twig\src\Environment.php#595: Twig\Environment->tokenize() .\vendor\twig\twig\src\Environment.php#408: Twig\Environment->compileSource() .\vendor\twig\twig\src\Environment.php#381: Twig\Environment->loadClass( string '__TwigTemplate_034511bee5325c368ee003e3d97d6cb47c3e1c94ebb527bcf0b76ba7818d1ac6', string 'javascript/variables.twig', NULL, ) .\vendor\twig\twig\src\Environment.php#359: Twig\Environment->loadTemplate(string 'javascript/variables.twig') .\libraries\classes\Template.php#99: Twig\Environment->load(string 'javascript/variables.twig') .\libraries\classes\Template.php#132: PhpMyAdmin\Template->load(string 'javascript/variables') .\libraries\classes\Header.php#714: PhpMyAdmin\Template->render( string 'javascript/variables', array, ) .\libraries\classes\Header.php#193: PhpMyAdmin\Header->getVariablesForJavaScript() .\libraries\classes\Header.php#142: PhpMyAdmin\Header->addDefaultScripts() .\libraries\classes\Response.php#184: PhpMyAdmin\Header->__construct() .\libraries\classes\Response.php#215: PhpMyAdmin\Response->__construct() .\libraries\classes\Plugins\Auth\AuthenticationCookie.php#102: PhpMyAdmin\Response::getInstance() .\libraries\classes\Plugins\AuthenticationPlugin.php#275: PhpMyAdmin\Plugins\Auth\AuthenticationCookie->showLoginForm() .\libraries\common.inc.php#263: PhpMyAdmin\Plugins\AuthenticationPlugin->authenticate() .\index.php#15: require_once(.\libraries\common.inc.php) Deprecation Notice in .\vendor\twig\twig\src\Markup.php#35 Return type of Twig\Markup::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice Backtrace .\vendor\composer\ClassLoader.php#444: include(.\vendor\twig\twig\src\Markup.php) .\vendor\composer\ClassLoader.php#322: Composer\Autoload\includeFile(string 'E:\\Soft\\OpenServer\\modules\\system\\html\\openserver\\phpmyadmin\\vendor\\composer/../twig/twig/src/Markup.php') .\tmp\twig\46\46f1bfbf4328d3d22fddffb9178fdeb9868d0740e4cc8b5bbd6f2fcfb8e4523e.php#59: Composer\Autoload\ClassLoader->loadClass(string 'Twig\\Markup') .\vendor\twig\twig\src\Template.php#405: __TwigTemplate_034511bee5325c368ee003e3d97d6cb47c3e1c94ebb527bcf0b76ba7818d1ac6->doDisplay( array, array, ) .\vendor\twig\twig\src\Template.php#378: Twig\Template->displayWithErrorHandling( array, array, ) .\vendor\twig\twig\src\Template.php#390: Twig\Template->display(array) .\vendor\twig\twig\src\TemplateWrapper.php#45: Twig\Template->render( array, array, ) .\libraries\classes\Template.php#132: Twig\TemplateWrapper->render(array) .\libraries\classes\Header.php#714: PhpMyAdmin\Template->render( string 'javascript/variables', array, ) .\libraries\classes\Header.php#193: PhpMyAdmin\Header->getVariablesForJavaScript() .\libraries\classes\Header.php#142: PhpMyAdmin\Header->addDefaultScripts() .\libraries\classes\Response.php#184: PhpMyAdmin\Header->__construct() .\libraries\classes\Response.php#215: PhpMyAdmin\Response->__construct() .\libraries\classes\Plugins\Auth\AuthenticationCookie.php#102: PhpMyAdmin\Response::getInstance() .\libraries\classes\Plugins\AuthenticationPlugin.php#275: PhpMyAdmin\Plugins\Auth\AuthenticationCookie->showLoginForm() .\libraries\common.inc.php#263: PhpMyAdmin\Plugins\AuthenticationPlugin->authenticate() .\index.php#15: require_once(.\libraries\common.inc.php) Deprecation Notice in .\vendor\twig\twig\src\Markup.php#40 Return type of Twig\Markup::jsonSerialize() should either be compatible with JsonSerializable::jsonSerialize(): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice Backtrace .\vendor\composer\ClassLoader.php#444: include(.\vendor\twig\twig\src\Markup.php) .\vendor\composer\ClassLoader.php#322: Composer\Autoload\includeFile(string 'E:\\Soft\\OpenServer\\modules\\system\\html\\openserver\\phpmyadmin\\vendor\\composer/../twig/twig/src/Markup.php') .\tmp\twig\46\46f1bfbf4328d3d22fddffb9178fdeb9868d0740e4cc8b5bbd6f2fcfb8e4523e.php#59: Composer\Autoload\ClassLoader->loadClass(string 'Twig\\Markup') .\vendor\twig\twig\src\Template.php#405: __TwigTemplate_034511bee5325c368ee003e3d97d6cb47c3e1c94ebb527bcf0b76ba7818d1ac6->doDisplay( array, array, ) .\vendor\twig\twig\src\Template.php#378: Twig\Template->displayWithErrorHandling( array, array, ) .\vendor\twig\twig\src\Template.php#390: Twig\Template->display(array) .\vendor\twig\twig\src\TemplateWrapper.php#45: Twig\Template->render( array, array, ) .\libraries\classes\Template.php#132: Twig\TemplateWrapper->render(array) .\libraries\classes\Header.php#714: PhpMyAdmin\Template->render( string 'javascript/variables', array, ) .\libraries\classes\Header.php#193: PhpMyAdmin\Header->getVariablesForJavaScript() .\libraries\classes\Header.php#142: PhpMyAdmin\Header->addDefaultScripts() .\libraries\classes\Response.php#184: PhpMyAdmin\Header->__construct() .\libraries\classes\Response.php#215: PhpMyAdmin\Response->__construct() .\libraries\classes\Plugins\Auth\AuthenticationCookie.php#102: PhpMyAdmin\Response::getInstance() .\libraries\classes\Plugins\AuthenticationPlugin.php#275: PhpMyAdmin\Plugins\Auth\AuthenticationCookie->showLoginForm() .\libraries\common.inc.php#263: PhpMyAdmin\Plugins\AuthenticationPlugin->authenticate() .\index.php#15: require_once(.\libraries\common.inc.php)
Согласно вашим наставлениям поставил в виртуалку Win11 полностью все с system-software-for-windows-3_5_5 что надо и не надо. Не заработало, очень странно ( Выходит у всех работает?SagePointer писал(а): ↑13 фев 2022, 22:07У всех остальных всё прекрасно запускается на Windows 11. Так что проблема явно не в Open Server и не в Windows 11. Может быть, кривую сборку винды поставили вместо оригинальной, или не установили runtime-компоненты Visual C++.
На чистой виртуалке, ставил только VirtualBox Additions и сам OpenServer (с основными компонентами и "Microsoft Visual C++ 2005-2022 Redistributable Packages"): Может быть, дело в этом самом "system-software-for-windows-3_5_5"?
