2020-12-10 19:57:50 --------------------------------------------
2020-12-10 19:57:50 Начало процедуры запуска сервера
2020-12-10 19:57:51 Обновление Hosts файла
2020-12-10 19:57:51 Обновление конфигурации MariaDB-10.3
2020-12-10 19:57:51 Обновление конфигурации Sendmail
2020-12-10 19:57:51 Обновление конфигурации PHP_7.1
2020-12-10 19:57:51 Обновление конфигурации PHPMyAdmin
2020-12-10 19:57:51 Обновление конфигурации Apache_2.4-PHP_7.0-7.1
2020-12-10 19:57:51 Запуск MariaDB-10.3
2020-12-10 19:57:51 Запуск Apache_2.4-PHP_7.0-7.1
2020-12-10 19:57:51 Проверка состояния сервера
2020-12-10 19:58:26 Не удалось запустить MariaDB-10.3
2020-12-10 19:58:26 Сбой запуска!
2020-12-10 19:58:26 --------------------------------------------
2020-12-10 19:58:26 Начало процедуры остановки сервера
2020-12-10 19:58:26 Остановка системных модулей
2020-12-10 19:58:27 Отключение виртуального диска
2020-12-10 19:58:27 Сервер успешно остановлен за 0,719 секунд!
Apache отладка
[Thu Dec 10 19:57:52.923570 2020] [ssl:warn] [pid 6836:tid 480] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name
[Thu Dec 10 19:57:53.067201 2020] [ssl:warn] [pid 6836:tid 480] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name
[Thu Dec 10 19:57:53.758627 2020] [mpm_winnt:notice] [pid 6836:tid 480] AH00455: Apache/2.4.41 (Win64) OpenSSL/1.0.2s configured -- resuming normal operations
[Thu Dec 10 19:57:53.758627 2020] [mpm_winnt:notice] [pid 6836:tid 480] AH00456: Apache Lounge VC14 Server built: Aug 12 2019 10:48:01
[Thu Dec 10 19:57:53.759272 2020] [core:notice] [pid 6836:tid 480] AH00094: Command line: 'C:\\openserver\\modules\\http\\Apache_2.4-PHP_7.0-7.1\\bin\\httpd.exe -d C:/OpenServer/modules/http/Apache_2.4-PHP_7.0-7.1 -f c:\\openserver\\modules\\http\\Apache_2.4-PHP_7.0-7.1\\conf\\httpd.conf'
[Thu Dec 10 19:57:53.764272 2020] [mpm_winnt:notice] [pid 6836:tid 480] AH00418: Parent: Created child process 5144
[Thu Dec 10 19:57:54.356134 2020] [ssl:warn] [pid 5144:tid 484] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name
[Thu Dec 10 19:57:54.469156 2020] [ssl:warn] [pid 5144:tid 484] AH01909: default:443:0 server certificate does NOT include an ID which matches the server name
[Thu Dec 10 19:57:54.514131 2020] [mpm_winnt:notice] [pid 5144:tid 484] AH00354: Child: Starting 150 worker threads.
MySQL отладка
error: Found option without preceding group in config file: c:\openserver\modules\database\MariaDB-10.3\my.ini at line: 1
Fatal error in defaults handling. Program aborted
Помогите ((
- Текущее время: 18 июн 2025, 01:47
