Не работает phpMyAdmin
realtoreal
30 янв 2013, 08:04
realtoreal » 30 янв 2013, 09:26
phpMyAdmin не работает - пишет "ошибка 101":
да и lockalhost/index.php тоже "Ошибка 101 (net::ERR_CONNECTION_RESET): Соединение сброшено."
причем через MySQLменеджер вроде работает, т.е. сам по себе mySQL рабочий, но через браузер ничего не отображается, вот логи
бд-запросы:
W:\modules\database\MariaDB-5.5.28a\bin\mysqld.exe, Version: 5.5.28a-MariaDB-log (mariadb.org binary distribution). started with:
Time                 Id Command    Argument
130130 11:40:16	    1 Connect	root@127.0.0.1 as anonymous on mysql
		    1 Quit
130130 11:51:57	    2 Connect	root@127.0.0.1 as anonymous on
		    2 Query	SET NAMES utf8
		    2 Query	SHOW STATUS
		    2 Query	SHOW VARIABLES
		    2 Query	SHOW DATABASES
		    2 Query	USE `information_schema`
		    2 Query	SELECT `DEFAULT_COLLATION_NAME` FROM `information_schema`.`SCHEMATA` WHERE `SCHEMA_NAME`='information_schema'
		    2 Query	SHOW TABLE STATUS FROM `information_schema`
		    2 Query	SHOW FUNCTION STATUS WHERE `Db`='information_schema'
		    2 Query	SHOW PROCEDURE STATUS WHERE `Db`='information_schema'
		    2 Query	SHOW TRIGGERS FROM `information_schema`
130130 11:51:58	    2 Query	SHOW EVENTS FROM `information_schema`
		    2 Quit
130130 11:52:17	    3 Connect	root@127.0.0.1 as anonymous on
		    3 Query	SET NAMES utf8
		    3 Query	SHOW STATUS
		    3 Query	SHOW VARIABLES
		    3 Query	SHOW DATABASES
		    3 Query	USE `information_schema`
		    3 Query	SELECT `DEFAULT_COLLATION_NAME` FROM `information_schema`.`SCHEMATA` WHERE `SCHEMA_NAME`='information_schema'
		    3 Query	SHOW TABLE STATUS FROM `information_schema`
		    3 Query	SHOW FUNCTION STATUS WHERE `Db`='information_schema'
		    3 Query	SHOW PROCEDURE STATUS WHERE `Db`='information_schema'
		    3 Query	SHOW TRIGGERS FROM `information_schema`
		    3 Query	SHOW EVENTS FROM `information_schema`
130130 11:52:18	    3 Query	SHOW CREATE TABLE `information_schema`.`COLLATION_CHARACTER_SET_APPLICABILITY`
		    3 Query	SHOW COLLATION
		    3 Query	SHOW ENGINES
основной:
2013-01-30 11:39:46  --------------------------------------------
2013-01-30 11:39:46  Начало процедуры запуска сервера
2013-01-30 11:39:48  Создание виртуального диска
2013-01-30 11:39:48  Обновление Hosts файла
2013-01-30 11:39:48  Обновление конфигурации MariaDB-5.5.28a
2013-01-30 11:39:48  Обновление конфигурации Sendmail
2013-01-30 11:39:48  Обновление конфигурации PHP-5.2.17
2013-01-30 11:39:48  Обновление конфигурации PHPMyAdmin
2013-01-30 11:39:49  Обновление конфигурации MemcacheAdmin
2013-01-30 11:39:49  Обновление конфигурации Apache-2.2.23
2013-01-30 11:39:51  Запуск MariaDB-5.5.28a
2013-01-30 11:39:51  Запуск Apache-2.2.23
2013-01-30 11:39:51  Проверка состояния сервера
2013-01-30 11:40:20  Веб-сервер успешно запущен!
http
localhost: 127.0.0.1 [30/Jan/2013:11:40:19 +0500] "GET /openserver/check.html HTTP/1.0" 200 18 "-" "Mozilla/4.0 (compatible; ICS)"
localhost: 127.0.0.1 [30/Jan/2013:11:40:19 +0500] "GET /openserver/check.php HTTP/1.0" 200 18 "-" "Mozilla/4.0 (compatible; ICS)"
http-отладка
[Wed Jan 30 11:40:09 2013] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Jan 30 11:40:09 2013] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Wed Jan 30 11:40:09 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed Jan 30 11:40:17 2013] [notice] Apache/2.2.23 (Win32) mod_ssl/2.2.23 OpenSSL/0.9.8x configured -- resuming normal operations
[Wed Jan 30 11:40:17 2013] [notice] Server built: Aug 24 2012 11:45:16
[Wed Jan 30 11:40:17 2013] [notice] Parent: Created child process 304
[Wed Jan 30 11:40:17 2013] [notice] Disabled use of AcceptEx() WinSock2 API
[Wed Jan 30 11:40:18 2013] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Jan 30 11:40:18 2013] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Wed Jan 30 11:40:18 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed Jan 30 11:40:19 2013] [notice] Child 304: Child process is running
[Wed Jan 30 11:40:19 2013] [notice] Child 304: Acquired the start mutex.
[Wed Jan 30 11:40:19 2013] [notice] Child 304: Starting 32 worker threads.
[Wed Jan 30 11:40:19 2013] [notice] Child 304: Listening on port 443.
[Wed Jan 30 11:40:19 2013] [notice] Child 304: Listening on port 80.
php-отладка - пустой
бд-отладка:
130130 11:40:03 InnoDB: The InnoDB memory heap is disabled
130130 11:40:03 InnoDB: Mutexes and rw_locks use Windows interlocked functions
130130 11:40:03 InnoDB: Compressed tables use zlib 1.2.3
130130 11:40:04 InnoDB: Initializing buffer pool, size = 10.0M
130130 11:40:04 InnoDB: Completed initialization of buffer pool
130130 11:40:04 InnoDB: highest supported file format is Barracuda.
130130 11:40:11  InnoDB: Waiting for the background threads to start
130130 11:40:12 Percona XtraDB (http://www.percona.com) 1.1.8-29.1 started; log sequence number 1597945
130130 11:40:12 [Note] Plugin 'FEEDBACK' is disabled.
130130 11:40:16 [Note] Event Scheduler: Loaded 0 events
130130 11:40:16 [Note] W:\modules\database\MariaDB-5.5.28a\bin\mysqld.exe: ready for connections.
Version: '5.5.28a-MariaDB-log'  socket: ''  port: 3306  mariadb.org binary distribution
130130 11:51:57 [ERROR] Incorrect definition of table mysql.proc: expected column 'sql_mode' at position 14 to have type set('REAL_AS_FLOAT','PIPES_AS_CONCAT','ANSI_QUOTES'...
вот черные окна:
OpenServer\userdata\profiles\Default.ini
[main]
start=10
allow=1
emformat=txt
maxmemcache=64
cgiprocess=5
pginitencode=UTF8
ip=127.0.0.1
mysqlrootpass=
postgresqlpass=
dbdriver=MariaDB-5.5.28a
mysqlcharset=utf8_general_ci
phpdriver=PHP-5.2.17
httpdriver=Apache-2.2.23
httpcharset=notset
logreadsize=256
showversion=1
astart=1
crdisk=1
crpath=0
crdomain=0
showfvr=0
showprogs=1
hdomains=0
balloon=1
favorite=0
showswitch=1
debugmode=1
stext=1
sbrowser=1
mysql=1
email=0
vdisk=W
webdir="domains"
browser="%realprogdir%\progs\_Internet\IronPortable\IronPortable.exe"
textred="%realprogdir%\progs\_Office\Notepad++Portable\Notepad++Portable.exe"
filebrowser="%realprogdir%\progs\_System\Explorer++Portable\Explorer++Portable.exe"
sfilebrowser=1
upurl=http://open-server.ru/update/
durl=http://open-server.ru/download.html
[ports]
mysqlport=3306
postgresqlport=5432
httpport=80
httpsport=443
httpbackport=8080
ftpport=21
phpport=9000
memcacheport=11211
[ftp]
ftp=0
ftpcommandtimeout=600
ftpconnecttimeout=60
[sendmail]
smtp_server=
smtp_port=
auth_username=
auth_password=
smtp_ssl=0
pop3_server=
pop3_username=
pop3_password=
force_sender=
MS XP Proffessional 5.1.2600 SP3
антивирус/фаервол ЕСЕТ нод 32:
и что еще могу сказать: интернет работает нормально
Максим » 30 янв 2013, 13:09
Вы подключили к новому серверу mysql каталог с базами данных от старого сервера. При этом не провели процедуру mysql upgrade, отсюда и проблемы.
Что нам говорит MYSQL:
start the server with the --skip-grant-tables option to cause it to skip the normal grant table checks, then run mysql_upgrade
значит так и делайте, запустите сервер вручную из командной строки с опцией --skip-grant-tables и выполните процедуру mysql_upgrade.
realtoreal
30 янв 2013, 08:04
realtoreal » 31 янв 2013, 08:10
Главное, что он вообще соединение сбрасывает, т.е. он даже без работы с базами mysql обычную страницу http://localhost/index.php не показывает - указывает ошибку, что соединение сброшено:
Подозреваю, что ваша программа здесь не при чем, что-то с системой. Наверное надо переустановить полностью.
Вообще, сначала точно так же перестал работать Денвер - запускаются базы, сервер, но соединение сбрасывает - вот я и попробовал вашу программу, но проблема осталась такая же. Сбрасывает соединение и все тут. И в hosts лазил и все такое, но где-то еще, видимо сломалось... дети побывали за компом в выходные
Максим » 31 янв 2013, 14:19
Полагаю за сброс подключений повинен ваш ЕСЕТ нод 32.
realtoreal
30 янв 2013, 08:04
realtoreal » 01 фев 2013, 07:38
блин точно, так и есть. вроде я делал ему исключения, но вот вырубить не пытался. как вырубил - заработало. если разберусь - отпишусь
