Максим, не выполняется ничего.
Сразу после запуска - сообщения об ошибках.
- Текущее время: 24 апр 2024, 04:56
ни localhost, ни другие домены, ни phpmyadmin не открываются через браузер. Пишет, что страница не доступна.DoNZa писал(а): В смысле не запускаются домены?
[Sun Jul 05 09:03:01 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:01 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:01 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:01 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:01 2015] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Sun Jul 05 09:03:01 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:01 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:01 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:01 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:01 2015] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Sun Jul 05 09:03:04 2015] [notice] Apache/2.2.29 (Win32) mod_ssl/2.2.29 OpenSSL/0.9.8zc configured -- resuming normal operations [Sun Jul 05 09:03:04 2015] [notice] Server built: Sep 10 2014 11:58:36 [Sun Jul 05 09:03:04 2015] [notice] Parent: Created child process 2736 [Sun Jul 05 09:03:04 2015] [notice] Disabled use of AcceptEx() WinSock2 API [Sun Jul 05 09:03:04 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:04 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:04 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:04 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:04 2015] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Sun Jul 05 09:03:05 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:05 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:05 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:05 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!? [Sun Jul 05 09:03:05 2015] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366) [Sun Jul 05 09:03:05 2015] [notice] Child 2736: Child process is running [Sun Jul 05 09:03:05 2015] [notice] Child 2736: Acquired the start mutex. [Sun Jul 05 09:03:05 2015] [notice] Child 2736: Starting 32 worker threads. [Sun Jul 05 09:03:05 2015] [notice] Child 2736: Listening on port 443. [Sun Jul 05 09:03:05 2015] [notice] Child 2736: Listening on port 80.
150705 9:02:59 [Note] Plugin 'FEDERATED' is disabled. 150705 9:02:59 InnoDB: The InnoDB memory heap is disabled 150705 9:02:59 InnoDB: Mutexes and rw_locks use Windows interlocked functions 150705 9:02:59 InnoDB: Compressed tables use zlib 1.2.3 150705 9:03:00 InnoDB: Initializing buffer pool, size = 20.0M 150705 9:03:00 InnoDB: Completed initialization of buffer pool 150705 9:03:00 InnoDB: highest supported file format is Barracuda. 150705 9:03:00 InnoDB: Waiting for the background threads to start 150705 9:03:01 InnoDB: 5.5.41 started; log sequence number 1595675 150705 9:03:01 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306 150705 9:03:01 [Note] - '127.0.0.1' resolves to '127.0.0.1'; 150705 9:03:01 [Note] Server socket created on IP: '127.0.0.1'. 150705 9:03:03 [Note] Event Scheduler: Loaded 0 events 150705 9:03:03 [Note] c:\openserver\modules\database\MySQL-5.5\bin\mysqld.exe: ready for connections. Version: '5.5.41-log' socket: '' port: 3306 MySQL Community Server (GPL)fairwall убрал, антивирусов нет. с портами в скайпе экспериментировал.
150731 11:49:21 [Note] Plugin 'FEDERATED' is disabled. 150731 11:49:21 InnoDB: The InnoDB memory heap is disabled 150731 11:49:21 InnoDB: Mutexes and rw_locks use Windows interlocked functions 150731 11:49:21 InnoDB: Compressed tables use zlib 1.2.3 150731 11:49:21 InnoDB: Initializing buffer pool, size = 20.0M 150731 11:49:21 InnoDB: Completed initialization of buffer pool 150731 11:49:21 InnoDB: highest supported file format is Barracuda. 150731 11:49:21 InnoDB: Waiting for the background threads to start 150731 11:49:22 InnoDB: 5.5.38 started; log sequence number 1595675 150731 11:49:22 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306 150731 11:49:22 [Note] - '127.0.0.1' resolves to '127.0.0.1'; 150731 11:49:22 [Note] Server socket created on IP: '127.0.0.1'. 150731 11:49:22 [Note] Event Scheduler: Loaded 0 events 150731 11:49:22 [Note] D:\OpenServer\modules\database\MySQL-5.5\bin\mysqld.exe: ready for connections. Version: '5.5.38-log' socket: '' port: 3306 MySQL Community Server (GPL) 150731 11:49:32 [Note] D:\OpenServer\modules\database\MySQL-5.5\bin\mysqld.exe: Normal shutdown 150731 11:49:32 [Note] Event Scheduler: Purging the queue. 0 events 150731 11:49:32 InnoDB: Starting shutdown... 150731 11:49:33 InnoDB: Shutdown completed; log sequence number 1595675 150731 11:49:33 [Note] D:\OpenServer\modules\database\MySQL-5.5\bin\mysqld.exe: Shutdown complete
2015-07-31 11:49:21 -------------------------------------------- 2015-07-31 11:49:21 Начало процедуры запуска сервера 2015-07-31 11:49:21 Обновление Hosts файла 2015-07-31 11:49:21 Обновление конфигурации MySQL-5.5 2015-07-31 11:49:21 Обновление конфигурации Sendmail 2015-07-31 11:49:21 Обновление конфигурации PHP-5.3 2015-07-31 11:49:21 Обновление конфигурации PHPMyAdmin 2015-07-31 11:49:21 Обновление конфигурации Apache-2.2 2015-07-31 11:49:21 Запуск MySQL-5.5 2015-07-31 11:49:21 Запуск Apache-2.2 2015-07-31 11:49:21 Проверка состояния сервера 2015-07-31 11:49:32 Не удалось запустить Apache-2.2 2015-07-31 11:49:32 Сбой запуска! 2015-07-31 11:49:32 -------------------------------------------- 2015-07-31 11:49:32 Начало процедуры остановки сервера 2015-07-31 11:49:32 Остановка системных модулей 2015-07-31 11:49:33 Отключение виртуального диска 2015-07-31 11:49:33 Веб-сервер успешно остановлен!
Что то не помогаетAlexandr писал(а):Аналогичная проблема, сразу после обновления с 7 на 10 перестал запускаться апач (и 2.2, и 2.4).
Решено - там какая-то "Служба веб-публикаций" появилась и занимает этот порт. Нужно просто её вырубить в панели управления или через командную строку(net stop W3SVC).
2015-08-01 14:29:22 -------------------------------------------- 2015-08-01 14:29:22 Начало процедуры запуска сервера 2015-08-01 14:29:22 Не удалось удалить файл C:\OpenServer\userdata\temp\ibE491.tmp 2015-08-01 14:29:22 Не удалось удалить файл C:\OpenServer\userdata\temp\ibE492.tmp 2015-08-01 14:29:22 Не удалось удалить файл C:\OpenServer\userdata\temp\ibE4D1.tmp 2015-08-01 14:29:22 Не удалось удалить файл C:\OpenServer\userdata\temp\ibE501.tmp 2015-08-01 14:29:22 Не удалось удалить файл C:\OpenServer\userdata\temp\ibE63B.tmp 2015-08-01 14:29:22 Невозможно занять порт 3306 поскольку он уже используется c:\openserver\modules\database\mysql-5.5\bin\mysqld.exe 2015-08-01 14:29:22 Сбой запуска!версия 5.1.1
