2012/02/05 01:32:25 [error] 5728#4040: *2 upstream timed out (10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond) while connecting to upstream, client: ip, server: guimp, request: "GET /check.php HTTP/1.0", upstream: "fastcgi://ip:9001", host: "guimp" 2012/02/05 01:32:26 [error] 5728#4040: *2 upstream timed out (10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond) while connecting to upstream, client: ip, server: guimp, request: "GET /check.php HTTP/1.0", upstream: "fastcgi://ip:9000", host: "guimp" 2012/02/05 01:32:27 [error] 5728#4040: *5 no live upstreams while connecting to upstream, client: ip, server: guimp, request: "GET /check.php HTTP/1.0", upstream: "fastcgi://backend", host: "guimp"Как решить данную проблему? Спасибо.
- Текущее время: 25 апр 2024, 13:55
