  Open Server скачали уже 1 440 180 раз!
Обновился с 5.1.1 до 5.2.2
Argus_xD
C нами: 2 года 11 мес
Непрочитанное сообщение Argus_xD » 30 янв 2015, 15:20
Apache
[spoiler][Fri Jan 30 17:11:10 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Fri Jan 30 17:11:10 2015] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Jan 30 17:11:13 2015] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 40 bytes)
[Fri Jan 30 17:11:13 2015] [notice] mod_bw : Version 0.92 - Initialized [0 Confs]
[Fri Jan 30 17:11:13 2015] [notice] mod_bw : Supported resolution for Timers [ Min: 1 Max: 1000000 ]
[Fri Jan 30 17:11:13 2015] [notice] mod_bw : Enabling High resolution timers [ 1 ms ]
[Fri Jan 30 17:11:13 2015] [notice] Apache/2.2.27 (Win32) mod_ssl/2.2.27 OpenSSL/0.9.8za mod_bw/0.92 configured -- resuming normal operations
[Fri Jan 30 17:11:13 2015] [notice] Server built: Mar 21 2014 10:41:53
[Fri Jan 30 17:11:13 2015] [notice] Parent: Created child process 4824
[Fri Jan 30 17:11:13 2015] [notice] Disabled use of AcceptEx() WinSock2 API
[Fri Jan 30 17:11:13 2015] [warn] RSA server certificate CommonName (CN) `openserver' does NOT match server name!?
[Fri Jan 30 17:11:13 2015] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Jan 30 17:11:13 2015] [notice] Child 4824: Child process is running
[Fri Jan 30 17:11:13 2015] [notice] Child 4824: Acquired the start mutex.
[Fri Jan 30 17:11:13 2015] [notice] Child 4824: Starting 32 worker threads.
[Fri Jan 30 17:11:13 2015] [notice] Child 4824: Listening on port 443.
[Fri Jan 30 17:11:13 2015] [notice] Child 4824: Listening on port 80.
[Fri Jan 30 17:11:23 2015] [error] [client 127.0.0.1] File does not exist: E:/OpenServer/domains/test/favicon.ico[/spoiler]
php [spoiler][30-Jan-2015 16:11:22 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: attributes construct error in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:22 Europe/Moscow] PHP Stack trace:
[30-Jan-2015 16:11:22 Europe/Moscow] PHP 1. {main}() E:\OpenServer\domains\test\index.php:0
[30-Jan-2015 16:11:22 Europe/Moscow] PHP 2. DOMDocument->load() E:\OpenServer\domains\test\index.php:5
[30-Jan-2015 16:11:22 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Couldn't find end of Start Tag thumbnail line 1 in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:22 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Premature end of data in tag group line 1 in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:22 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Premature end of data in tag entry line 1 in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:22 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Premature end of data in tag feed line 1 in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:28 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: AttValue: ' expected in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:28 Europe/Moscow] PHP Stack trace:
[30-Jan-2015 16:11:28 Europe/Moscow] PHP 1. {main}() E:\OpenServer\domains\test\index.php:0
[30-Jan-2015 16:11:28 Europe/Moscow] PHP 2. DOMDocument->load() E:\OpenServer\domains\test\index.php:5
[30-Jan-2015 16:11:28 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: attributes construct error in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:28 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Couldn't find end of Start Tag thumbnail line 1 in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:28 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Premature end of data in tag group line 1 in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:28 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Premature end of data in tag entry line 1 in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:28 Europe/Moscow] PHP Warning: DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Premature end of data in tag feed line 1 in http://gdata.youtube.com/feeds/api/videos/, line: 1 in E:\OpenServer\domains\test\index.php on line 5
[30-Jan-2015 16:11:28 Europe/Moscow] PHP 2. DOMDocument->load() E:\OpenServer\domains\test\index.php:5[/spoiler]
ставил denwer xampp
ошибки те же самые
причём ставлю 5.1.1 ошибка остётся
5.2.2 установил компоненты VC++ после чего php стал ругаться
Strict standards: Non-static method JLoader::import()
