[spoiler]2014-09-10 16:55:40 --------------------------------------------
2014-09-10 16:55:40 Начало процедуры запуска сервера
2014-09-10 16:55:40 Обновление Hosts файла
2014-09-10 16:55:40 Обновление конфигурации MySQL-5.5
2014-09-10 16:55:40 Обновление конфигурации Sendmail
2014-09-10 16:55:40 Обновление конфигурации PHP-5.3
2014-09-10 16:55:40 Обновление конфигурации PHPMyAdmin
2014-09-10 16:55:40 Обновление конфигурации Apache-2.2
2014-09-10 16:55:40 Запуск MySQL-5.5
2014-09-10 16:55:40 Запуск Apache-2.2
2014-09-10 16:55:40 Проверка состояния сервера
2014-09-10 16:56:03 Не удалось запустить MySQL-5.5
2014-09-10 16:56:03 Сбой запуска!
2014-09-10 16:56:03 --------------------------------------------
2014-09-10 16:56:03 Начало процедуры остановки сервера
2014-09-10 16:56:03 Остановка системных модулей
2014-09-10 16:56:03 Отключение виртуального диска
2014-09-10 16:56:03 Веб-сервер успешно остановлен!
[/spoiler]
[spoiler]140910 16:55:43 [Note] Plugin 'FEDERATED' is disabled.
140910 16:55:43 InnoDB: The InnoDB memory heap is disabled
140910 16:55:43 InnoDB: Mutexes and rw_locks use Windows interlocked functions
140910 16:55:43 InnoDB: Compressed tables use zlib 1.2.3
140910 16:55:43 InnoDB: Initializing buffer pool, size = 20.0M
140910 16:55:43 InnoDB: Completed initialization of buffer pool
140910 16:55:43 InnoDB: highest supported file format is Barracuda.
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
140910 16:55:43 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
140910 16:55:46 InnoDB: Waiting for the background threads to start
140910 16:55:47 InnoDB: 5.5.38 started; log sequence number 1595675
140910 16:55:47 [Note] Recovering after a crash using mysql-bin
140910 16:55:47 [Note] Starting crash recovery...
140910 16:55:47 [Note] Crash recovery finished.
140910 16:55:47 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
140910 16:55:47 [Note] - '127.0.0.1' resolves to '127.0.0.1';
140910 16:55:47 [Note] Server socket created on IP: '127.0.0.1'.
140910 16:55:49 [Note] Event Scheduler: Loaded 0 events
140910 16:55:49 [Note] D:\OPENSE~1\OPENSE~1\userdata\temp\3582-490\mysqld.exe: ready for connections.
Version: '5.5.38-log' socket: '' port: 3306 MySQL Community Server (GPL)
[/spoiler]
- Текущее время: 25 апр 2024, 02:04
